when i get back from basic i plan on getting a cam setup, push rods/springs/retainers but want to know if the vs is good a mild to average cam? (pros and cons) thank you in advance
more power than stock, more torque than stock, easier on valvetrain than the bigger cams, less power than bigger cams.
cool?
thank you, so if i plan on getting intercooled and staying between 3.0 - 3.2 (pulley) it would be fine, im guessing so
Probably.
thanks again, yea i might go with a diff. one but just curious being the next 14 weeks i wont be able to research much,
Love my new VS Cam. Go for it.
Is the VS all loud and lopey like the XP is? Or does it retain more of a stock exhaust sound?
Also, with the VS or any aftermarket cam... is the power difference throughout the whole rpm band?
Or is it like hv3 or headers where you'd only really see a difference higher in the rpms?
Vs is gears more toward the lower to mid upper range versus the xp which is more higher range. It's loopy of course but not easily noticeable like the xp. there is no substitute for the cam so headers wouldn't be a close comparison. I went the vs route since i plan on IC down the road and didn't want a real aggressive cam and wanted to keep it as DD friendly as I could.
either cam will add power across the entire power band. XP adds more above 5700 than a VS.
Imo, if idle speed is set correctly, a VS shouldnt lope, and an XP should sound like an epic misfire.
