Thread: Random misfires
Results 1 to 3 of 3
  1. #1 Random misfires
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    So the new engine in my car is idling rough and I'm getting random misfires in cyl 3 4 5 6.. It's runs fine when cold its just when it warms up... It has new wires new plug new coil packs and the vacuum lines are fine. Any ides?
    The mods are headers 1.9 rockers 3.3 pulle zzp ECM.. No cat zzp exhaust
  2. #2 Re: Random misfires
    GT Level Member Beelzeboul's Avatar
    Racine
    had this same problem swapped injectors around as it was a little confined but it ended up being a bad fuel bump but Id say check the usual culprits fuel pressure test injector harness test and finally injector test after that you can rule out fuel flow another thing would be the the ICU the coil packs mount too and the ground wire from it that connects to the engine block if your able to scan check your ltfts and make sure its not running to rich or lean.other common things to check would be tapping on your MAf to make sure its not on its way out and sending bad reading
    I'm sorry officer I didnt know I couldn't do that
  3. #3 Re: Random misfires
    Nov 2009
    canada
    Maf is new but I know it got coolant on it, maybe... Lol I had a leak from the throtle body that stalled the engine but fixed that...
  1. Misfires in Cyl 4
    By mousemonster1232 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 02:38 PM
  2. misfires??
    By paulaxe in forum Engine
    Last Post: 11-23-2010, 04:09 PM
  3. Bad rear 02 sensor and random misfires. Can runs just fine.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2009, 04:41 PM
  4. random misfires
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-14-2009, 06:26 AM
  5. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
