Today my car turned over but didn't fire and start like I've mentioned before. This time it took two trys then the final third try she turned over fine. I've noticed this problem to be the most severe today!!! Could it be the temp, today's been the coldest for awhile in the morning 63*f.
Any thoughts maybe CPS dirty from brake carbon dust, CPS is new, all bottom to top is new, besides a few top end sensors, TPS is fine, IAC is fine, MAF seems ok, no trouble codes.
I think i may vacuum leak but I doubt it Ive checked everywhere with brake cleaner, of few people have been helping me we think its the brake booster but im not to postive. No trouble codes mods are Arp from bottom to top, Comp Cams pushrods factory length, Factory cam, rebuilt with new crankshaft, l32 rods & l67 pistons, Clevite on mains & rods, oil pump, CAS etc, block was honed etc, ZZP Stg p&p filled with 105lb springs etc, ZZP high volume oil pressure spring, Plog, crossover, rear PEM, 3'' catless dp, rear 02 emulator, HPTuners rear 02 codes deleted, FWI, 3.8 pulley, 195 stat, AL 606 at .60, all solid poly engine, trans, dogbone mounts,
no misfires when engine is under load or when its cruising.
