Thread: Car won't start please help
Results 1 to 17 of 17
  1. #1 Car won't start please help
    Aug 2012
    Cushing, OK
    Ok guys so last night my car was running just fine I got home went to bed blah blah blah and now this morning it won't fire up it cranks but won't start we did have a little rain last night idk if that would affect anything. Anyways I checked the ignition fuses and they all seemed to be good I'm lost on these cars please help me thanks in advance and I do have new plugs and wires and fuel filter
  2. #2 Re: Car won't start please help
    Mar 2012
    NC
    Need spark and fuel. When you turn the key does the fuel pump kick on?
  3. #3 Re: Car won't start please help
    Does it crank slowly? Have you tried starting it with starting fluid?
  4. #4 Re: Car won't start please help
    Aug 2012
    Cushing, OK
    It doesn't crank slow no.. And I couldn't hear the fuel pump I tried listening for it... But even if it was the fuel pump wouldn't my car have started for just a second with the fuel it still had?
  5. #5 Re: Car won't start please help
    What kind of car do you have?
  6. #6 Re: Car won't start please help
    Aug 2012
    Cushing, OK
    2000 grand prix gtp
  7. #7 Re: Car won't start please help
    Pull the fuel pump resistor and bend out the 83? tab and see if it stays running. If that doesn't work then unplug the maf and see if it runs.
  8. #8 Re: Car won't start please help
    Aug 2012
    Cushing, OK
    I tried all that and neither worked and resistor??? You meant relay right??? The pump still isn't running though..
  9. #9 Re: Car won't start please help
    Oct 2011
    Southington, CT
    make sure that all of your vaccume lines are connected. i was having a similar issue the past two days along with other issues. noticed that one of the plastic vaccume lines cracked (due to excessive heat i believe) fixed it and now it seems to be running fine, it atleast stays started.
  10. #10 Re: Car won't start please help
    Have you tried staying fluid yet? I meant relay.
  11. #11 Re: Car won't start please help
    Dan.. won't help. The high speed relay is used when priming the fuel system. The resistor is low speed and kicks in when the car starts. Therefore it should start and die if the resistor is at fault.
    OP. Turn the key to on and press down on the valve on the fuel rail. Do you get any fuel spurting out? If not, check your fuel pump fuse.
    If that has fuel. Remove one plug wire at the coil pack. Try starting it. You should hear a loud zapping noise of the spark jumping.
    Let us know what you find.
  12. #12 Re: Car won't start please help
    Aug 2012
    Cushing, OK
    All the fuses are good replaced both relays and the pump is not running what so ever. So I'm pretty sure the pump it self died
  13. #13 Re: Car won't start please help
    You can test for power at the tank connector.
  14. #14 Re: Car won't start please help
    Jun 2012
    Richburg,SC
    Quote Originally Posted by Blowblackorgetback View Post
    2 relays ? which two and did you replace fuel pump ?
  15. #15 Re: Car won't start please help
    Elk, please start a new thread of your own wtih your symptoms listed. It's very uncommon for the relays to be an issue.
  16. #16 Re: Car won't start please help
    Jun 2012
    Richburg,SC
    It's very uncommon for the relays to be an issue. ok, but wouldn't it have been a lot nicer to have just wrote this <<<<<
  17. #17 Re: Car won't start please help
    I was nice. Had I wanted to be mean, evil or even just rude, I would have locked the thread and said.... start your own newb.
    Instead I suggested starting your own thread, which would tell us all your actual symptoms and give us a better chance of pinpointing the issue for you quickly instead of having you freeze to death (it's winter here) testing relays that don't typically fail. My suggestions are from experience (most of the time) and aimed at getting your car running for the least amount of money and time. I'm usually a very helpful guy, with an occasional bit of sarcasm.
    Sorry if I stepped on your kindergarten achievement award when I suggested posting a thread for only your issues. (Now... that you can say, wasn't nice). I even said please!
  1. Car won't start!!!
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 05:49 PM
  2. where to start
    By krimsonwolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 05:03 PM
  3. No start. Need help!
    By Phurst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 09:09 AM
  4. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  5. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
