Thread: I got some serious issues following zzp 350 pump install
Results 1 to 20 of 20
  1. #1 I got some serious issues following zzp 350 pump install
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    I ordered the zzp350 fuel pump with venturi option according to their website said i needed that option. i have a 2000 gtp, now first i had the small venturi line with really no place for it to go so im not sure which is correct cuz wbodystore says that for a 2000 u dont need it, but zzp says ido.
    im lost the pump looks retarded in the canister my car dies when braking hard and it runs super lean shortly after WOT. before someone askes yes i have a hotwire kit. i also noticed when i turn the key on and it primes it doesnt hold pressure. i dont know if i got a bad pump, or wrong pump or what. at idle it bounces around 40psi when i rev it up sitting still it goes up to about 50.
    im in a bad way as its my daily im hoping someone can shed some light on what could be wrong.
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: I got some serious issues following zzp 350 pump install
    Feb 2009
    flintnasty MI
    Fail.
    You have a non venturi bucket.. and you need a venturi bucket to run a venturi pump.
    Jun 2010
    Beloit, WI
    Yea i just figure it out lol, how coukd i get a non venturi bucket when all 97-00 supercharged got them. Maybe previous owner replaced pump with the whole wrong assembly
    Sent from my SCH-R760 using Tapatalk 2
    --00 Red GTP--
    13.07@108mph
    Ohio
    No the previous owner replaced it with a stock replacement...
    All replacements are non venturi. You are gonna **** **** up if you keep that pump.
    It's gonna die on you completely in a couple days.
    What are your mods? I doubt you need that big of pump.. Not even a 400 some wheel horse car needs that
  5. #5 Re: I got some serious issues following zzp 350 pump install
    Ohio
    nvm on the mods list..i was on tapatalk and couldn't see it.
    hmmm even on e85, most people have used a stock gm replacement.
    Jun 2010
    Beloit, WI
    I kno i coulda got away with prolly a stock replacement and rewire. But ive always been almost maxxed out on my injectors and figured that ill just go big and not worry about it. Im heading to the self service lkq and ill pick up a venturi canister for like 8 bucks
    --00 Red GTP--
    13.07@108mph
    Ohio
    I'd try and get a new pump, you've done damage to that one and it's not gonna stay good or get better.
    Ohio
    And really, I'd go for a detschewerks pump.
    Jun 2010
    Beloit, WI
    What part of my message makes u think its damaged.
    --00 Red GTP--
    13.07@108mph
    Ohio
    The fact that you've ran it dry..
    That part
    Ohio
    Fuel pumps need fuel to keep them lubricated..
    And it being a venturi pump, really warrants the imminent failure of it soon enough.
    Plus, there is probably a pressure leak somewhere in the main feed line on top of the pump to the top of the canister.
    Jun 2010
    Beloit, WI
    I was just curious because i got some answers from them about the function of the pump. They are willing to swap it for me but should i have the swap it for non venturi so it will fit the replacement basket i got or just get another venturi and get a venturi basket from the junkyard
    --00 Red GTP--
    13.07@108mph
    Ohio
    Okay.. If they are cool about it, then have them send you a non venturi.
    I'm glad they are being understanding about the matter and that's very kind of them.
    A non venturi is easier to work with and one less line to worry about in the event of a failure.
    Jun 2010
    Beloit, WI
    Okay i just wasnt sure if a regular pump would perform as well as it should in my tank compared to OEM equipment
    --00 Red GTP--
    13.07@108mph
    Jun 2010
    Beloit, WI
    Yea surprisingly they were pretty willing to swap me for the correct pump without much hassle
    --00 Red GTP--
    13.07@108mph
  16. #16 Re: I got some serious issues following zzp 350 pump install
    Feb 2009
    flintnasty MI
    i doubt this.. I have never seen a pump that uses the 01+ style pickup.
    Ohio
    Scott what are you doubting?
  18. #18 Re: I got some serious issues following zzp 350 pump install
    Not all 2K's were built the same. I was going to preorder a pump when I was getting the current 2000. Was told, that it could be one of two pumps. I think 2000 was the change over and you should check the tag to ensure which pump you have.
    Jun 2010
    Beloit, WI
    Yes i went through that whole.junkyard pulled prolly 10 canisters one was actually from another 00 gtp and it was a regular non venturi.
    But on a side notr i found the one and only venturi style canister in the whole place. And it worka perfect holds pressure, starts perfect, doesnt run dry no issues here. (except running pig rich with my tune)
    --00 Red GTP--
    13.07@108mph
    Ohio
    Hopefully it stays that way. I'd check the pressure again in a week
  1. Need Help! ZZP fuel Pump install wtf?
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 10:02 AM
  2. Fuel pump install.
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 11-12-2011, 10:51 AM
  3. Oil pump issues?
    By 90oddz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2011, 10:46 PM
  4. Water Pump Install for '03 GP SE?
    By sb76 in forum General Tech Discussion
    Last Post: 12-22-2010, 10:18 PM
  5. MSD Pump Booster Install
    By GTP01SE in forum General Tech Discussion
    Last Post: 06-18-2009, 10:06 AM
