Thread: hesitating then dies
Results 1 to 11 of 11
  1. #1 hesitating then dies
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    okay here's whats up. got a 98 gtp and the whole winter it never acted up till the weather warmed up yesterday. I was driving around since it was nice out and after a stoplight the motor would hesitate to run and would spit and sputter. so i threw her in neutral and shut it off, waited a few seconds then turned it back on and away she went. It still does it tho a few minutes later or if im at another stop light. is goin on???? Possibly MAF? any ideas anyone? I want to get it fixed asap cuz its embarrassing to see a gp in the middle of traffic not moving! thanks
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  2. #2 Re: hesitating then dies
    Never Never Land
    miles?
  3. #3 Re: hesitating then dies
    Waterloo, Iowa
  4. #4 Re: hesitating then dies
    Never Never Land
    ever done your crank sensor? mine would randomely die and randomely not start before i changed my crank sensor
  5. #5 Re: hesitating then dies
    Waterloo, Iowa
    nope never replaced that, i just put new plugs wires and a pcv valve in it tho, and im still gettin ****ty gas mileage
  6. #6 Re: hesitating then dies
    other gas milage dealio stuff are o2 sensor's
  7. #7 Re: hesitating then dies
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    i thought the cam sensor controlled engine fire and the crank was only for the gauges...get a scan guy to know for sure..there are a few things that could cause this and instead of randomly replacing parts save a ton of money and know for sure
  8. #8 Re: hesitating then dies
    Feb 2010
    somewhere cold
    also check fuel pressure as with that mileage your pump may be on the verge
  9. #9 Re: hesitating then dies
    Never Never Land
    crank sensor is used to determine fueling and such along with the tach
    basically when your crank sensor stops working its telling your computer the motor is not moving therefore it wont deliver any fuel or spark thus the motor dying.
  10. #10 Re: hesitating then dies
    Feb 2010
    somewhere cold
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    okay cause mine went out and even through the code for the crank sensor a few years back and the car ran just fine but the tach didnt work...after replacement the tach worked fine so i just assumed the cam sensor controlled all that
  11. #11 Re: hesitating then dies
    Never Never Land
    my tach would randomely stop working...mine never threw a code
  1. Engine hesitating while driving
    By forgerat1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2010, 11:17 AM
  2. Engine surging, hesitating (It's Fixed !!!)
    By BDEGhost in forum General Tech Discussion
    Last Post: 05-27-2010, 08:36 PM
  3. engine hesitating
    By deryk in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2010, 12:31 PM
  4. hesitating shifts
    By kinglou10 in forum General Tech Discussion
    Last Post: 06-26-2009, 01:21 PM
  5. Hesitating shifts
    By Andrew_99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 01:03 PM
