Multiple options. Scan gauges, there are computer adapter that plug into the ODB2 port and read out to a laptop, palm pro, blue-tooth ones send a signal to apple/android phones, I personally use our GM Tech2 scan tool at work periodically to run on the car and make sure everything is working right... but my situation is different than most lol.
But frankly until you get into modding deeply you really don't need to worry about scanning. If you are on the stock pulley and stock tune most of what you do first is just supporting mods so the engine can handle the added boost or other mods. Stepping stones, you don't just go to the end. Have to stage it.
Actually, I'd get a way to scan first and foremost...doesn't matter if you run 15's or 10's...knowing what your car is doing is very important; especially with as old as these platforms are getting.
