Thread: i have a few questions i could use your guys help with PLEASE!!!
Results 1 to 8 of 8
  1. #1 i have a few questions i could use your guys help with PLEASE!!!
    Aug 2012
    Cushing, OK
    ok first of all i have a 2000 gtp with straight exhaust with mufflers and i have bungs welding to the pipe the cat is gone and I'm getting a SES light saying o2 sensor bank 1 sensor 1 from my understanding the bank 1 sensor 2 is normal when running no cat but is the other one going to hurt me?? let me know what you guys think i also have a custom tuned cpm coming from overkill.. so will that pcm eliminate the need for the o2 sensors??? if so ill just wait it out and not worry about getting a new sensor or doing whatever else i may have to do to fix that particular issue
    also when the car is idling and i have the ac on the rpms kinda bounce but its only when the ac is on and its not really your normal compressor kicking on and off its more of an actual bounce of the rpm not just a slight bump down on rpm..
    and the last thing is when i put the car in park it kind of bounces back and fourth before it actually just quits and stops i think its the motor mounts so what do i need to replace as far as motor mounts and where do you guys recommend getting them? also going from forward to reverse and vise versa you can somewhat feel the motor kind of shift it feels like and if you hit the breaks hard you can feel it somewhat shift forward
    thanks in advance guys
  2. #2 Re: i have a few questions i could use your guys help with PLEASE!!!
    You still need an o2 sensor no matter what.
    The front o2 is needed always, the rear o2 is of no use if you are catless.
    So seeing that you have a bank 1 sensor 1 code, you need to fix that.
  3. #3 Re: i have a few questions i could use your guys help with PLEASE!!!
    Aug 2012
    Cushing, OK
    Thanks man appreciate the help and I need the sensor one even with the custom PCM
    An also what about the motor mounts ??
  4. #4 Re: i have a few questions i could use your guys help with PLEASE!!!
    pop your hood, then start the car and shift it from park to reverse to drive.( watch the engine) if the engine is moving a lot you need new lower engine and trans mounts.
    the pcm. you need to tell overkill to set the pcm to not report the other o2 sensor, the one by the cat. that way the cel light wont come on for that.
  5. #5 Re: i have a few questions i could use your guys help with PLEASE!!!
    Aug 2012
    Cushing, OK
    Ok thanks man
  6. #6 Re: i have a few questions i could use your guys help with PLEASE!!!
    Feb 2009
    flintnasty MI
    I deleted the O2 sensors on all 4 of my 3800 cars. Lean cruise > all.
  7. #7 Re: i have a few questions i could use your guys help with PLEASE!!!
    Entirely outside the realm of this thread.
  8. #8 Re: i have a few questions i could use your guys help with PLEASE!!!
    And doesn't work.
    Yay, DHlogic.
  1. Few questions for the 97-03 guys running 04-08 seats
    By buickman104 in forum Visual/Body Modifications
    Last Post: 06-21-2012, 03:13 PM
  2. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  3. Just a few questions guys.
    By RavagerX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2010, 01:16 AM
  4. Wiring questions for you electronic guys out there...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 06-14-2008, 05:19 PM
  5. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
