Thread: NIC Cam
Results 1 to 15 of 15
  1. #1 NIC Cam
    Sep 2012
    Ames, Iowa
    I'm putting in the nic this winter. Should I run 90# or 105# springs? I don't intend to shift over 6000rpm. Its not a race car, just a fun dd/weekend car with a nasty sound for when I feel like driving something more comfortable than my Camaro lol. Just looking for spring recommendations. Thanks in advance
  2. #2 Re: NIC Cam
    Banned
    CT
    105# only, good luck with the setup
  3. #3 Re: NIC Cam
    Feb 2009
    flintnasty MI
    Either work fine.
  4. #4 Re: NIC Cam
    May 2012
    Where winter never ends
    105#. From what I read when I was doing a cam, the 90s are harder on the valvetrain due to their seat pressures at full extension. I run 105s on a stock timing chain setup.
    2000 Regal - Winter Beater
  5. #5 Re: NIC Cam
    Banned
    CT
    The 90s just suck... I'm not sure why people run them.
  6. #6 Re: NIC Cam
    They were budget alternatives that in fact did work when 105's were not even near the price of the LS6's.
  7. #7 Re: NIC Cam
    Feb 2009
    flintnasty MI
    Ls6 srpings work great for most everything.
  8. #8 Re: NIC Cam
    GTX Level Member crbquist's Avatar
    Massachusetts
    My vote goes to 105's.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  9. #9 Re: NIC Cam
    Dec 2011
    Cortland
    Why not just run stock if your 100% positive you won't go over 6k
  10. #10 Re: NIC Cam
    Quote Originally Posted by SLOGTP98 View Post
    Stock springs couldn't handle that cam.
  11. #11 Re: NIC Cam
    that cam is recommended to use a double roller and 130# springs on the zzp website..........
  12. #12 Re: NIC Cam
    Feb 2009
    flintnasty MI
    Stock springs would work fine for most people.
  13. #13 Re: NIC Cam
    Massachusetts
    I would never run stock springs for any aftermarket cam, even a VS. Better safe than sorry.
  14. #14 Re: NIC Cam
    Banned
    CT
    On an NIC cam?
    This is dangerous information.. It's like you're trying to get people to blow their engines.
  15. #15 Re: NIC Cam
    Massachusetts
    Quote Originally Posted by SnowFlake View Post
    On an NIC cam?
    I concur..
