Thread: Was noisey now runs poorly
Results 1 to 6 of 6
  1. #1 Was noisey now runs poorly
    Aug 2012
    Richland oregon
    I was on a road trip started with a ticking sound then got louder, after driving two more hours the ticking went away so I assumed the problem was not valve train related, Is it possible I have something wrong in the valve train yet the valve train is now very quiet. At this time engine is quiet I have a check engine light on engine runs rough, engine runs smoother with coil 1/4 disconnected, have changed ICM and 1/4 coil.
    Thanks
  2. #2 Re: Was noisey now runs poorly
    Checked spark plugs yet?
    And can you get the code number so we know what the car is saying.
  3. #3 Re: Was noisey now runs poorly
    GT Level Member Beelzeboul's Avatar
    Racine
    its always a good idea to get a statement from the car when possible
    I'm sorry officer I didnt know I couldn't do that
  4. #4 Re: Was noisey now runs poorly
    Aug 2012
    Richland oregon
    I would love to pull the codes, perhaps I'm just being cheap as I'm 60 miles to the nearest shop and they charge $250 for a tow. If I had a problem with a rocker or lifter would I always hear noise?
  5. #5 Re: Was noisey now runs poorly
    If we knew the codes you where throwing it would help out a ton.
  6. #6 Re: Was noisey now runs poorly
    Go buy a cheap code reader for $40
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. 1997 GTP running poorly in boost
    By sswisley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 02:54 PM
  3. Replies: 1
    Last Post: 01-17-2012, 09:24 PM
  4. Noisey Aluminum Roller Rockers?
    By MeanGTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2010, 07:33 PM
  5. Gen V Swap, Noisey Blower Now
    By scottmmckinney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2009, 12:21 PM
