Thread: booooost
Results 1 to 20 of 30
  1. #1 booooost
    SE Level Member YZ250rider's Avatar
    Aug 2012
    Sioux Falls, SD
    So, I've had my '98 GTP for about 3 weeks now, and I was wondering about my stock boost gauge. When I step on it, the gauge only goes to about half way. Is this normal? or should I be concerned with something being wrong?
  2. #2 Re: booooost
    The Boss Iceman6669's Avatar
    Jun 2011
    It will only go half way when you FLOOR it and hold it there??
    2011 F-150 Yote powered
  3. #3 Re: booooost
    Aug 2012
    Sioux Falls, SD
    Yeah
  4. #4 Re: booooost
    Jun 2011
    Then yes something is prolly wrong. I mean it could just be the lights are burnt out.. BUT it sounds like you have a VAC leak or your BBV is not working right. You are doing this in DRIVE not in Park right.
  5. #5 Re: booooost
    Aug 2012
    Sioux Falls, SD
    Yes. This is as I'm either driving or going from a complete stop
  6. #6 Re: booooost
    Jun 2011
    Ok. Just wanted to make sure.. I would start by looking for a vac leak.
  7. #7 Re: booooost
    Aug 2012
    Sioux Falls, SD
    I just looked and the vac line under the supercharger looked like it wasn't broken or leaking anything.
  8. #8 Re: booooost
    Jun 2011
    The best way to check is to have the motor running and spray carb cleaner or starting fluid on the vac lines. IF you have a leak you will hear the RPMs spike.
  9. #9 Re: booooost
    Aug 2012
    Sioux Falls, SD
    just sprayed carb cleaner on the vac line under the s/c and the other t-fitting and rpms stayed the same
  10. #10 Re: booooost
    GT Level Member fri3dchick3n's Avatar
    Alaska
    How about your SC belt, is it squeaking any? If it is, replace it.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  11. #11 Re: booooost
    Jun 2011
    Did you do ALL the vac lines??? Including the one that runs from under the snout to the MAP sensor on the back of the motor?
  12. #12 Re: booooost
    Aug 2012
    Sioux Falls, SD
    just sprayed all three and there was no rpm rise. if my belt is squeeking then i cannot really hear it.
  13. #13 Re: booooost
    Jun 2011
    sounds to me like your BBV or your BBV solenoid is bad
  14. #14 Re: booooost
    Aug 2012
    Sioux Falls, SD
    What is that and what can i do to check?
  15. #15 Re: booooost
    Resident ZZP Leg Humper BoostenGTP's Avatar
    Grand Rapids, MI
    Unplug the boost bypass valve, its in front of the throttle body. Unhook the wire harness from it and see what happens. If you get full boost back, the BBV is shot, just unhook it, you don't need it. Drive the car, see what happens.
    2014 Mustang GT Sterling Grey 5.0 Track Package NEW 2000 Grand Prix GTP Red SOLD
    2000 Mustang GT LTR SOLD 2000 Grand Prix GTP Silvermist SOLD
  16. #16 Re: booooost
    Grand Rapids, MI
    Here I made a diagram for you.
    remove the RED painted vacuum line, just remove that T and hook it up to the top of the fuel rail there. The Blue circle is the electrical plug for the bypass valve, its under that harness. Just remove it. The green is the boost bypass valve, just unplug the red vac line from that, let it stay open on the BBV plug, don't cap it off. I had the same issue and THIS fixed it. Hope this helps.
  17. #17 Re: booooost
    Aug 2012
    Sioux Falls, SD
    which one is it?
  18. #18 Re: booooost
    Aug 2012
    Sioux Falls, SD
    so can you color me a picture of where the vac line goes and exactly which harness to pull?
  19. #19 Re: booooost
    Grand Rapids, MI
    I did... the red vac line goes BYE BYE, same with the Vac T on the fuel lines, just hook it into the fuel rail. Just look under your hood and you'll see what i'm talking about. behind that harness there is an electrical plug for the boost bypass valve.
  20. #20 Re: booooost
    Iowa
    Quote Originally Posted by YZ250rider View Post
    you sir...are a retard.
