Thread: parts interchangibilty between a 1999 and a 2004 comp g
Results 1 to 18 of 18
  1. #1 parts interchangibilty between a 1999 and a 2004 comp g
    Kemmerer, Wyoming
    Im trying to find an article on what parts, if any, will swap over from a 1999 to a 2004 comp g. im mostly interested in the exhaust if it would be a direct fit or a close fit but im also curious if there are any other parts that would fit. also, is it possible to get the transmission out of a 1999 and have it rebuilt to match the performance characteristics of the comp g.
  2. #2 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Ohio
    99 tranny and comp g tranny are totally different...comp g has paddle shifters. exhaust is all the same
  3. #3 Re: parts interchangibilty between a 1999 and a 2004 comp g
    04+ cars need 04+ trans that matches the car it came out of.
    Anything before that (97-03) can't work, internals are different and the way its controlled via the PCM aswell.
  4. #4 Re: parts interchangibilty between a 1999 and a 2004 comp g
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    Clearance for headers is a little different but it will work with some elbow grease
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
    Kemmerer, Wyoming
    The engine its pretty much the same, right?
    Sent from my YP-G70 using Tapatalk 2
  6. #6 Re: parts interchangibilty between a 1999 and a 2004 comp g
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    The internals on the 4T65E are the same I think in both 99 and 04+ and the engines blocks are the same as well. Only difference is in the PCM, torque converter and gear ratio.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  7. #7 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Quote Originally Posted by t24moore View Post
    Internals are almost the same but still different.
    Everything from 2003 and above has a differnet valve body, newer clutches etc etc, hard parts, and is controlled via the PCM different that than a 97-02.
    Flex plates are different as well IIRC.
    The motors are the same block, you'd have to swap your brackets and parts over to it to make it bolt right in, then if you kept the GEN V blower, you will have to research on how to make it work on the 97-03 cars. Headers are a must if you went that way, or you could swap your top end over and call it a day.
  8. #8 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Feb 2008
    Houston
    I cant find anything anywhere supporting your claims of hardened parts, valve body changes, or clutches. GM hasnt changed the 4T65 as far as im aware when it comes to the w-body. Also looking on trannymans site there is no price difference when it comes to these transmissions. Now the Volvo 4t65 has a different valve body but not ours. The flex plate is only different due to the differences in torque converter sizes. But thats more of a NA block versus SC block thing rather than a year specific issue.
  9. #9 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Williamsburg, Ky
    I didn't know the torque converter was different. What is different about them?
    Kemmerer, Wyoming
    I probably should have said this in the beginning of the topic but I have a 1999 gtp and am considering getting an 04 comp g. In my 99 I have full exhaust and intake and am running a 3.4 with no knock . all I really would want to do is swap the exhaust.
    The comp g has an upgraded suspension right?
  11. #11 Re: parts interchangibilty between a 1999 and a 2004 comp g
    If you have headers, those will swap over.
    The catback might be different.
    If you planned on putting the 3.4 on it, I'd advise against it.
    Kemmerer, Wyoming
    I have pems and a catless dp and I was going to do a 3.6 after the intake and exhaust are done
  13. #13 Re: parts interchangibilty between a 1999 and a 2004 comp g
    GT Level Member Beelzeboul's Avatar
    Racine
    think it said in the brake thread rotors and calipers are swappable
    I'm sorry officer I didnt know I couldn't do that
  14. #14 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Hopefully you have a scangauge of some sorts. The car may or may not take well to the pulley drop. IMO pems wont flow enough and you'll see KR and need the stock pulley or a custom tune.
  15. #15 Re: parts interchangibilty between a 1999 and a 2004 comp g
    GT Level Member Toms04compg's Avatar
    Michigan
    Yeah pcm is diff , tb on genv diff , someone said gear ratio the same the comp has the 3.29 i would rather have that. Comp doesnt have performance suspension as far as i know. But struts and what not are different from 97 to 03 i have an 04 and kyb were different part#. You can make the comp suspension the same as the other years just need that years lca i belive.
  16. #16 Re: parts interchangibilty between a 1999 and a 2004 comp g
    The 4T65-E was introduced to replace the 4T60-E in 1997. The 4T65-E included a larger 258 mm torque converter for some models and many other changes to improve reliability. It is able to handle vehicles up to 6500 lb (2948 kg) GVWR with up to 280 ft·lbf (380 N·m) of torque. A number of final drive ratios are available, with many distinct models. Starting in mid year 2000 models, all 4T65-E models received an upgraded valve body. Starting in 2003 the internal electronics were changed, hardened 4th gear shaft, ratcheting sprags for input and third gear were added.
    Found that.
    So?
    And in 2003 the valve body was changed again and the electronics, hence why the 03 is a year only transmission.
    And 04+ cars have newer and better parts than the 97-03 cars, technology in them.
  17. #17 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Feb 2008
    Houston
    I forgot about the fancy tap shift, so youre correct that the valve body is different to compensate for that. But far as new and better parts.....thats debatable. I still think the series 2 L67 is the best engine. Also over the past 6 years we have never bricked a 97 PCM. And my axles are from my 97 GTP that wrecked with a ton of track passes on them. I just recently replaced one boot. I personally think the newer stuff is cheaper. Its been proven already that the L67 had stronger rods. Technology isnt always better on cars IMO.
  18. #18 Re: parts interchangibilty between a 1999 and a 2004 comp g
    Omaha, NE
    The comp G trans is not interchangable with any other trans. I forget exactly what the compatability issue was, but there is one.
    Also switching gear ratios requires a tune to compensate for the change.
  1. 2004 gtp comp g
    By 90cobraclone in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2012, 10:39 AM
  2. 2004 Comp G
    By 04BlackComp_G in forum For Sale - Vehicles
    Last Post: 02-04-2012, 11:17 PM
  3. 2004 comp g
    By nickbato in forum Introductions/Noob Questions
    Last Post: 03-20-2011, 10:24 PM
  4. my new 2004 Comp G!
    By colindunn in forum Off Topic Discussion
    Last Post: 10-31-2010, 08:57 PM
