Thread: Gen V Swap
Results 1 to 20 of 21
  1. #1 Gen V Swap
    May 2012
    Burlington, Wisconsin
    So, I bought a Gen V to swap into my 98 GTP a few months ago. I've finally saved up some money to buy all the parts necessary to put it in, but wanted to double check I didn't miss anything. How did I do with my research?
    ZZPerformance - Gen 5 to L67/L36 Throttle Body Adapter Plate #ZZ-GEN5L67L36-TBA
    ZZPerformance - Injector O-Rings #ZZ-INJORNG-8 x 2
    GM ACDelco - Intake Gasket #GM-89017825
    GM ACDelco - OEM L32 Supercharger Gasket #GM-12574474
    ZZPerformance - Lower Intake O-Rings #ZZ-LINTORG-38
    alternator relocation kit
    I plan on intercooling which is why I want to relocate the alternator. I don't know how exactly I will do that, though. Any advice/recommendations to add?
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  2. #2 Re: Gen V Swap
    Omaha, NE
    It looks like you've got it all. It wouldn't hurt to change the coupler before you install the supercharger for peace of mind.
    I have an alternator relocation kit I'll sell. Brand new from ZZP. PM Me if interested.
  3. #3 Re: Gen V Swap
    May 2012
    It looks like you've got it all. It wouldn't hurt to change the coupler before you install the supercharger for peace of mind.I have an alternator relocation kit I'll sell. Brand new from ZZP. PM Me if interested.
    Seller claimed he changed the coupler right before he sold it to me. I'll definitely private message you about the kit though.
  4. #4 Re: Gen V Swap
    May 2012
    Anyone else want to add anything? Want to make sure it's done right.
  5. #5 Re: Gen V Swap
    You don't need the LIM o-rings for a Gen 3 SC. The yellow rings are not needed. The gasket you selected has o-rings built into it. That is the gasket for the early LIM or if you open up a Gen 3 LIM. The 07+ LIM did not have recessed areas for the o-rings and require the metal gasket.
    Don't see any coolant elbows in your stuff.
  6. #6 Re: Gen V Swap
    May 2012
    I'm swapping in a Gen 5. That's the list I could come up with after research. I got a new LIM with the Gen 5, don't know the different between the two though. Also, I'm doing coolant elbows when I flush my coolant before I put on the Gen 5. Could you correct anything for me? Thanks man!
  7. #7 Re: Gen V Swap
    The gasket you bought will be for a LIM with recessed coolant port areas like the below picture.
    The yellow o-rings you simply don't need. They are for the L67 (Gen 3) supercharger gasket because on that gasket..the rings aren't part of the gasket. The gasket you bought..it's tough to see..but the rings are part of it and you don't need the additional rings.
    The 07+ gasket is flat metal and has inlaid rubber. The LIM on that newer style is flat in the coolant port area, similar to this L36 manifold. The one hole here that you can see in the lower left is the flush coolant port I am speaking about.
    Here's the 07 Gen V gasket
    And here is a Gen V gasket (your version) laid over a Gen 3 gasket. You can see the coolant o-rings are part of the Gen V gasket. You can also see how much the LIM is different on the two chargers
    Being that you are going to a Gen V. I would suggest plugging the coolant ports and opening up the turn around area as noted in this thread
    http://www.grandprixforums.net/how-mod-lim-46931.html
  8. #8 Re: Gen V Swap
    May 2012
    Looking through your pictures, it looks like the asshole I bought the Gen V from gave me a LIM for a Gen III with it and not a Gen V. Looks like I'm going to have to go buy another one before I even consider putting it on. Thanks for the help though, will come in handy when I get the LIM.
  9. #9 Re: Gen V Swap
    Hold up.. first off.. you can modify a Gen 3 for a Gen V and not need to spend anything.
    Toss up a picture and let's see what you have. Then go from there.
  10. #10 Re: Gen V Swap
    May 2012
    Here is what it currently looks like:
    Thanks for bearing with me. I've never dealt with superchargers and lims before.
    Ohio
    Well luckily its already opened up for an intercooler
  12. #12 Re: Gen V Swap
    May 2012
    Quote Originally Posted by 99pgpgt View Post
    Is it really? From the ones I have compared it to that claim to be intercooler ready this seems different.
    Mercer, Pa
    It's opened up to much by the boost bypass hole. The PCV passage that runs around the boost bypass hole (gen 5) won't seal. This manifold will work with a Intercooler but may not seal right without it.
  14. #14 Re: Gen V Swap
    May 2012
    Quote Originally Posted by sseilmnop View Post
    So it will work with one, but will it work without one too?
    Mercer, Pa
    Quote Originally Posted by Btownmills View Post
    Yes should work with Intercooler. May not work without Intercooler.
  16. #16 Re: Gen V Swap
    May 2012
    Thanks a lot for the help man. Looks like I'm going to have to scrape up some money before putting the charger on. Does my list in the main post still look right for the Gen V swap though?
    Mercer, Pa
    Take a look at gasket picture. You can see a bent hotdog shape by the boost bypass hole that has to seal. Put gasket on LIM and see if enough material is left.
  18. #18 Re: Gen V Swap
    List looks good besides 2 new coolant elbows and you might want to get valve cover gaskets while you're in there. Also it's best to block off the two coolant passages on the lower intake manifold. It's as simple as tapping and plugging the holes. Also have you figured out what you're going to do with the PCV and EVAP system? Most people just block off the EVAP on the Gen v charger and re-use the stock EVAP. The PCV system is a little more complicated from what I remember. I believe you need to drill/tap the throttle body and run a vacuum line from this to the PCV nipple on the back of the gen v charger. You can't just tap the throttle body anywhere, i believe it has to be anywhere after the MAF sensor & before throttle plate. Also you will need that alternator relocation bracket or you'll need a 99+ alternator,bracket, and bolts. Make sure to get RTV so you can install the block off plate on the gen V as well. You'll need the gen v supercharger bolts. Two 5qts of oil, new oil filter, coolant.
  19. #19 Re: Gen V Swap
    You're list is still including the extra coolant o-rings. And remember the part where I mentioned the metal Gen V gasket for the flat LIM, you have two choices. You can plug the coolant ports and open the coolant turn around like in the "how to mod a lim" thread that is linked then remove the o-ring area of your gasket so it sits flat because your LIM doesn't have the recessed areas. Or you can get the metal gasket instead. Either way no coolant reaches your throttle body. Therefore my suggestions is to plug and open the other area.
    EVAP: If you are using an L67 throttle body, you can use the Gen V's original Evap soleniod on it instead of plugging the hole. Simply hook up your line from the fuel tank to it and the electrical connector. Presto you are all set, plug the hole on the side of the TB where it originally went on your engine
    PCV: You drill and tap into the bottom of the stock TB to retain proper PCV functionallity. This is if you aren't intercooled.
  20. #20 Re: Gen V Swap
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    should i still tap the tb if i am intercooled with a gen v and using a gen 3 lim and gen 3 core?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  1. What is a top swap?
    By Btincher98GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2013, 12:36 PM
  2. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  3. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  4. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  5. L36 Swap
    By g4m3r7ag in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2011, 06:52 PM
