Thread: motor swap idle queston. (VIDEO)
Results 1 to 20 of 30
  1. #1 motor swap idle queston. (VIDEO)
    GT Level Member Utter99's Avatar
    Warsaw indiana
    ok so i just put a supercharged motor in my grand prix gt got everything put together today and started it up. it idles really iffy.
    I just have the headers on the car as of right now. i also deleted the egr and i think the hvac is still off . but not sure if it was needed . please let me know if it needs to be on the car
    i have codes but no reader with me and i dont want to drive it to the aouto parts because im waiting on top motor mounts. just curios to seee what you guys think . i checked all the vacum lines and with carb cleaner didnt notice any leaks. the idle slowly but steadily rises. opinions??
    I also pulled maf sensor and had no idle change. also when i got to rev it up a little it tries to die on me...
    Thanks in advance
    55585d01.mp4 video by JustinUtter - Photobucket
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  2. #2 Re: motor swap idle queston. (VIDEO)
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    Look like maybe something to do with the IAC motor?
    New project: 2000 Red GTP.
  3. #3 Re: motor swap idle queston. (VIDEO)
    What pcm did you use?
  4. #4 Re: motor swap idle queston. (VIDEO)
    Warsaw indiana
    i am using a gtp pcm i got off ebay programmed to my vin
  5. #5 Re: motor swap idle queston. (VIDEO)
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    mine did that at first crank up on my swap.. changed maf it went fine
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  6. #6 Re: motor swap idle queston. (VIDEO)
    Warsaw indiana
    i have another throttle body laying with all the sensors in it. ill just switch them and see how it works out for me
  7. #7 Re: motor swap idle queston. (VIDEO)
    Also check the throttle and cruise cables to ensure they aren't pulling the throttle open.
  8. #8 Re: motor swap idle queston. (VIDEO)
    Warsaw indiana
    i know that one of the springs were bad in the throttle body i have . i switched the one that was broke out with another one from another throttle body of the same kind. i reset the springs i know they are where they are supposed to be .but the correct tension i don't know. i could just get the spring wrapped around just one time. maybe when the cars running all the vacuum is making that butterfly open because the springs don't have enough tension.?
  9. #9 Re: motor swap issue with more info. (VIDEO)
    Warsaw indiana
    so my car will start up and die trying to idle. then it will shoot up to 2500 to 3500 hundred rpms. i tried unplugging the maf and the iac but it didnt change anything . i went through all my vacuum lines about twenty times now so im sure theres no leak . my gauge is reading about 15 to 20 of vacuum. so what could it be?
    like stated above im running just headers i deleted the egr and evap. i also noticed that when i rev it revs fine and the boost does enagage when its in park. and that there is a little black smoke that comes out the pipes. and my plugs were really dark dry sought. not good since i have prolly five minutes of run time.
    i really need help to get this car going again. i went through and put all new gaskets on the motor from top to bottom and even lapped the valves. my car was orignally the gt model and i though maybe the fuel pump wont work right with this setup? i know its long but i tried to be as descriptive as possible. any help would be greatly appreciated
  10. #10 Re: motor swap idle queston. (VIDEO)
    brunswick
    tps in backwards?
    if maf didnt change maybe its bad>?
    maybe blower gasket not sealed>?
    maybe egr block offs arent as gooda as thought to be and sucking in air?
    did you bend the tab back on the pump speed relay ?
  11. #11 Re: motor swap idle queston. (VIDEO)
    Apr 2009
    Fort Worth TX
    There is an idle screw on the TB.
    Loosen it all the way and see if idle RPM goes down.
    If it does then you're getting unmetered air into the engine.
    Make sure the EGR isn't leaking.
    Did you spray carb cleaner where the supercharger meets the LIM?
    If you didn't use any RTV on the SC gasket; take it off and do this.
  12. #12 Re: motor swap idle queston. (VIDEO)
    I'll help you out again as soon as you report back on trying what I suggested. So how about it... wanna help me, help you?
    Warsaw indiana
    I didn't bend the tab back on the speed tab really .. What is this?
    Also bill I looked at what you said the throttle body is completely closed I promise lol.
    Also I know the get is sealed completely I did it from the side and from the inside of the minifold.
    Supercharger gasket has no leaks I tested with carb cleaner and I did rtv it to the lim and the charger .
    Warsaw indiana
    An the tps Ian the connection part supposed to be facing the intake cone?
  15. #15 Re: motor swap idle queston. (VIDEO)
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Utter99 View Post
    Please someone decipher for me?
    Warsaw indiana
    Lol my bad Rico it's hard to type on this iPhone . But what I was asking was is the tps sensor the part that has the connector on it . Is that supposed to be facing the inlet side of the throttle body where you would put your filter?
  17. #17 Re: motor swap idle queston. (VIDEO)
    Yes.. however it's possible to put the sensor on incorrectly and have it sitting in that orientation.
    Warsaw indiana
    Yeah I know what you bean bill I know how to install it correctly .
  19. #19 Re: motor swap idle queston. (VIDEO)
    Ok, just trying to answer you as fully as possible. You double checked the IAC is working properly and is clean?
  20. #20 Re: motor swap idle queston. (VIDEO)
    Warsaw indiana
    Yes i unplugged it and the idle and everything with the car acted the same. I even switched it out with one off my other throttle body
  1. New Build almost done! Cam idle video
    By bballa0740 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2011, 11:39 AM
  2. Help.. Strange Idle (video) after 1.9's/LIM gasket -
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:33 PM
  3. L67 motor swap (with video)
    By ninnyGTP in forum How To Write-Ups/Tech Tips
    Last Post: 01-24-2011, 04:23 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. Land Rover Motor Swap (Video)
    Last Post: 03-19-2008, 08:44 AM
