Thread: XPZ vs XP
Results 1 to 20 of 33
  1. #1 XPZ vs XP
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Hey there guys I need some insight before I purchase the right cam for my build.
    Current car specs
    98 GT
    112K miles
    Pacesetter headers
    Full exhaust
    Bored over .030
    Mods waiting to go on the car (Top swap of course)
    Gen v SC w 2.7 pulley and lim
    N* set up
    ZZP stage 3 IC core with stage 2 FMHE
    LS7 lifters
    L67 PNP heads with 105# hardened retainers and steel valves
    (Double roller or single roller?)
    42.5# injectors
    ZZP modded fuel rail
    8 rib set up
    ZZP plug wires
    AEM wideband
    Any ideas on which cam I should go with?
    Its going to be a DD.
    I am afraid that the XPZ might be a little TOO aggressive.
    I would like to get some opinions on what one I should pick...
    Thanks!
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  2. #2 Re: XPZ vs XP
    Mar 2012
    NC
    Another cam thread? Ok, it all depends on what you're after. The XP is great for a daily driver and isn't too lopey. The XPZ is geared more towards higher RPM operation, is much more lopey, and will probably cause an idle surge. Both cams have high power potential depending on what you want to do. I opted for the XP after driving a car with one. I really liked where the cam made its useful power.
  3. #3 Re: XPZ vs XP
    Since it's a DD I would go w/ Xp.
    04 Comp G.
  4. #4 Re: XPZ vs XP
    Round lake, IL
    How much of a difference in power will I see with the XP over the XPZ?
  5. #5 Re: XPZ vs XP
    Mar 2012
    NC
    It's not necessarily the power difference as much as where it is useful. We need more power in the mid-range for the street...since the XPZ is geared towards higher end power, it kinda makes it less fun. Unless of course, you constantly live above 4000 RPM. The XPZ is capable of more power because of the high RPM nature and other attributes of the cam profile, but the XP will give you about 80% of that power at a lower RPM. So figure maybe 25-30 WHP difference.
  6. #6 Re: XPZ vs XP
    Round lake, IL
    I am getting a good deal on an XPZ with rods, so I am trying to weigh the pros and cons, I do most of my racing on the streets, so living above 4K is probably where I am at most of the time lol
  7. #7 Re: XPZ vs XP
    Mar 2012
    NC
    If that's what you like to do then go XPZ. Get the double roller, have the crank sprocket machined correctly to correct the chain geometry, get the heads done properly for the XPZ, get yourself a built trans, IC setup, the whole works and go out and race things.
  8. #8 Re: XPZ vs XP
    Round lake, IL
    Well my goal is to see mid to low 12s.... if my set up is capable of that with the XP then I can settle with that and a single roller
  9. #9 Re: XPZ vs XP
    Mar 2012
    NC
    XP has seen low 12's on a few cars.
  10. #10 Re: XPZ vs XP
    Why no custom grind?
    Why no S1X or IS3?
    Why no turbo setup that won't cost as much as that blower setup and make more power?
    Just playing devil's advocate brah. I loved my XP. XPZ doesn't impress me. But then again, neither does most blower setups because the money poured into them and they still don't break 375~400 WHP.
  11. #11 Re: XPZ vs XP
    Round lake, IL
    I didnt do much research on the turbo set up, i plan on top swapping myself, the turbo build would be too tough for me, and even so I would not k now where to start and how much the kit will run me.
  12. #12 Re: XPZ vs XP
    Look at it this way.
    ZZP's base Z3 kit on a GT (for around two grand or less if you can find stuff used...which is the way to go IMO) with the addition of some crap EBay intercooler and piping you can fab up yourself for cheap = 350+ WHP when running over 12~ psi I'd imagine.
    Also, only thing about that is you have to remove the downpipe, tuck some harness' away from the turbo, and other small crap.
    No head removal.
    No balancer removal.
    Everything stays on, as do the fluids...well minus the oil change because you have to run a feed line from the pan level sensor.
    I'd venture to say it is quiet easier to do than a top swap IMO.
    I've done a couple Top Swaps...they aren't fun. I'd rather pull the motor than do that crap in the car.
  13. #13 Re: XPZ vs XP
    Round lake, IL
    Ugh it just sucks I went trough 8 months of friggin headaches with my 02 GTI build, i freaking hated working on it, but see here, just because i get the turbo kit doesnt mean I should keep everything else stock does it? Will i benefit by using my l67 PNP heads with 105# springs? Should I still do LS7 lifters? single roller? Obviously kit doesnt come with a cam, going to need that too.... idk where to start
  14. #14 Re: XPZ vs XP
    Round lake, IL
    Maybe I should find someone to trade.....
  15. #15 Re: XPZ vs XP
    SELL SELL SELL!
    Be the smart man.
  16. #16 Re: XPZ vs XP
    Top swap in car is easy. Only time consuming bits are wiring harness modifications and headers.
  17. #17 Re: XPZ vs XP
    If you run the ported L67 heads, you'll need the blower case and block off the rotor pack....since the injector bosses are in the heads...or you can still run the N/A top end if you have the injector holes welded shut in the N/A LIM....and this single roller kick is meh. Run a new stock chain and dampner...don't run a dumb low idle like I did and you'll be fine. Plenty of failure rates with single and double rollers...
    Ask my two crank gears how I know.
    And removing the heads is fun?
    No thanks, "smart smart" guy.
  18. #18 Re: XPZ vs XP
    Its easy, 8 bolts per head and it pops right off.
    The only painful part I had last time around was home ported heads. They aren't joking when they say most will give up. Luckily I had four months.
  19. #19 Re: XPZ vs XP
    Minnesota
    Save your money. Buy used turbo kit and get a built trans. You will thank me later.
    --I should have done that and I have a top swap. I think a lot of people would say the same thing.
  20. #20 Re: XPZ vs XP
    Quote Originally Posted by Pure2sin View Post
    If you want to make power yes, but I don't. I'm content wandering around the high 200's with a cool blower whine.
    Haven't broke the trans yet. I'll probably break it now won't I.
    Regardless, I'm not interested in a $3000 trans just to hold 350-400 WHP.
    Quote Originally Posted by 99pgpgt View Post
    Wait.. Wtf?
    Why would you use l67 heads? Then you have to top swap it anyways.
    Leave everything alone, only reason to modify the valve train is if you did a cam or rockers.
    The 350 whp nick said, is with stock cam.. You add even just a gt cam to it.. You're looking at around 400 whp
    TGP- 266whp- 10 PSI, intercooled CT kit PT 61, M90 block off, 2.5" exhaust, 42lb injectors, CT PCM, , L67 MAF, 42lb injectors, 18" wheels
    TGP- 286whp- 11 PSI, Intercooled, CT kit PT 61, M90 block off, plog, 2.5" exhaust, LT1 MAF, ZZP PCM, 42lb injectors, Racetronix fp, 18" wheels
    TGP- 346whp- 12 PSI, Intercooled, CT kit PT 61, M90 block off, plog, 2.5" exhaust, cutout, LT1 MAF, ZZP PCM, 42lb injectors, Racetronix fp, 1.9 rockers, 16" wheels
    Ideally you'd use L26/L36 top end on an L67/L32. You get slightly better flowing heads, much better LIM/UIM and low compression.
xpz
