Thread: getting a P0135 code
Results 1 to 13 of 13
  1. #1 getting a P0135 code
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hey guys I would like to get some advice on how to get rid of this engine light, I am getting a P0135 code which is the 02 sensor i guess. Would simply replacing the sensor remove this code?
    Does it matter what kind of sensor to get?
    For example there are some cheap ones on ebay.
    Car has 70 000 miles on I don't think sensors have ever been changed. No other codes are being thrown.
    What else can I do if a new sensor does not work??
    Thanks
  2. #2 Re: getting a P0135 code
    Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
    I would just replace the sensor with a new OEM one. Buy cheap ones and they will die on you.
  3. #3 Re: getting a P0135 code
    May 2011
    Ontario
  4. #4 Re: getting a P0135 code
    not with 22 dollar shipping. i would not be getting that one.
  5. #5 Re: getting a P0135 code
    GTP Level Member buickman104's Avatar
    NYC
    I've never had any problems with Denso O2 sensors for our cars.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: getting a P0135 code
    May 2011
    Ontario
    also with that code does that mean you need to replace 1 or 2 sensors?
  7. #7 Re: getting a P0135 code
    NYC
    Primary sensor I believe. The one bolted on by your rear manifold.
  8. #8 Re: getting a P0135 code
    May 2011
    Ontario
    Thanks I will order the part and try this in a week or so. Hopefully it deletes the engine code.
  9. #9 Re: getting a P0135 code
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    is the O2 sensor zzp sells any good?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  10. #10 Re: getting a P0135 code
    St. Louis
    Check www.rockauto.com for one. They usually have good prices.
  11. #11 Re: getting a P0135 code
    Oct 2011
    Michigan
    i was considering zzps O2 sensor but will it be bad?
  12. #12 Re: getting a P0135 code
    Why does it have to be ZZP.
    A Denso/delco from napa or where ever is prolly the same exact price and you dont have to pay shipping, just drive there.
  13. #13 Re: getting a P0135 code
    Oct 2011
    Michigan
    i havent tried nappa but autozone was $20 more and i would be buying like 4 things from zzp at once so shipping wouldnt be a big deal
  1. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  2. Need help with a code?
    By FRESCOLIO in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-13-2011, 11:24 AM
  3. help! code po 716
    By SteveCZ28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2011, 07:38 AM
  4. another SES code...
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 10:27 PM
  5. P0135 - replace o2 sensor?
    By dirtmaster88 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:08 PM
