Thread: Leaking fuel line
Results 1 to 10 of 10
  1. #1 Leaking fuel line
    Apr 2011
    Gainesville, FL
    I have a 97 GTP in which the one of the plastic fuel lines is leaking just behind where it connects to the fuel rails on top of the supercharger. Is there any problem with just replacing these plastic parts of the fuel lines with rubber fuel hose and pipe clamps? Not really wanting to invest much more money into this car. Thanks
  2. #2 Re: Leaking fuel line
    Might be the o-rings in teh connector. You can replace them. If it's the end.. maybe a dorman repair kit?
  3. #3 Re: Leaking fuel line
    Apr 2011
    Gainesville, FL
    Its not near the metal lines. Its cracked right in the plastic part. I repaired it once before with JB weld but its leaking again. The leak is not where the slip connectors are.
  4. #4 Re: Leaking fuel line
    Perfect..go check the help section for the dorman repair kit.
  5. #5 Re: Leaking fuel line
    Apr 2011
    Gainesville, FL
    Is there a problem with just using rubber fuel line and hose clamps and replacing the entire plastic sections?
  6. #6 Re: Leaking fuel line
    Quote Originally Posted by jpearsall187 View Post
    yes you can do it that way but think about it like this, that line has up to 50 psi in it. so id fix it right. if it pops off you wont need to fix THIS CAR any more, it will burn.
  7. #7 Re: Leaking fuel line
    No, there's nothing wrong with FI rated line and I'd double up the FI clamps on both ends. Actually when I did that, I also added a slight bubble flare to the fuel rail and the metal tube.
    Easiest place to get the fuel line will be where it bends from under the car to up into the engine bay on the drivers side.
  8. #8 Re: Leaking fuel line
    I live here. TLSheff's Avatar
    Whatever you choose to do, make sure it done right so it won't leak again.
    Fuel + Hot Manifolds + time =
    You don't want this ^ This is bad ^
  9. #9 Re: Leaking fuel line
    Apr 2011
    Gainesville, FL
    How did you make the bubbles?
  10. #10 Re: Leaking fuel line
    you need a flair tool. but that would be the safe way, if the tube is left smooth it has a greater chance of coming off. hose clamps alone are only worth so much. even doubled up.
  1. Leaking Fuel Injector Line
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 06-03-2012, 02:55 PM
  2. Trans Cooler Line Leaking
    By johng80 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2011, 12:05 PM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. Fuel line leaking at the supercharger
    By ohioGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2009, 07:38 AM
  5. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
