Thread: Running lean- Opinions?
Results 1 to 8 of 8
  1. #1 Running lean- Opinions?
    GTP Level Member Ultra440's Avatar
    Ohio
    I have run a few scans since my header install and I'm running between a +3% to +11% LTFT. It only goes a little negative when Im punching the throttle. Im pretty sure before my header install my LTFT %s were -3% to +3% or so. My tuner guy said I could bring the car in to have the MAF tables readjusted... I was hoping it was that simple but after reading about 2001+ vehicles having a cat diagnostic test run with the rear 02 sensor I began to think there was a correlation. However, I'm running lean, not rich. I had the sensor in before the headers but unplugged it completely when I installed them. P0420 (or whatever the rear 02 code is) was deleted during my tune and as I said before, my LTFT looked pretty close to zero pre-headers. Any help is appreciated.
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  2. #2 Re: Running lean- Opinions?
    Out West
    ethanol.
    Whine with your Cheese?
  3. #3 Re: Running lean- Opinions?
    Ohio
    Quote Originally Posted by Nixon View Post
    ethanol.
    Soon man... Gotta figure out my dented fender first. Im even tempted to cam before the corn...
  4. #4 Re: Running lean- Opinions?
    Can you prove this running lean though?
    Whats your wideband saying?
  5. #5 Re: Running lean- Opinions?
    Ohio
    No wideband unfortunately and im not even considering STFT... Rich/Lean status parameter flashes rich-lean back and forth, not sure if thats worth a **** or not. Im showing like no KR whatsoever either, wouldnt lean cause some KR? I just thought LTFTs were supposed to stay plus or minus 5%....
    Edit- My knock sensors are working, I see blips of like .2 and .5 here and there.
  6. #6 Re: Running lean- Opinions?
    Out West
    between 0 and -5 is best.
  7. #7 Re: Running lean- Opinions?
    Ohio
    Okay, Slightly rich for protectiOn. But 0 constantly would be best, right? Plus or minus 5 is an ideal range considering it likely won't stay at 0 all the time
    So, without a wideband, using only a scanner and the fuel trim readings, I am unable to see exactly if my a/f is ideal? Is that what I'm understanding?
  8. #8 Re: Running lean- Opinions?
    Out West
    ideal range is 0 to -5.
  1. Running lean?
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2012, 01:05 PM
  2. Im running too lean?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-13-2011, 12:36 PM
  3. Running lean
    By camarofan1974 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 03:25 PM
  4. running lean?
    By Brennan7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:07 AM
  5. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
