Thread: Help! Gas Mileage Dropping
Results 1 to 6 of 6
  1. #1 Help! Gas Mileage Dropping
    Jan 2012
    Utah
    Howdy. My Super 3.8L motor blew at 84K even tho I drove it gently. Go figure. I replaced it with a 46K engine (same type)...started it up, all computers came on line and checked out. We replaced EVERYTHING replaceable when we did the swap - plugs, wires, pumps, filters, etc. Smooth as silk from the day of the install. The motor seems to run fine, no codes, smooth, etc. My gas mileage had dropped from close to 21 all around with the old motor, to 17 with this one. Embarrassed to say that I don't know if this happened recently or since the motor was replaced 20K ago.
    ANYONE help me out? What are your thoughts about the diff in mileage? - oh, and replaced the plugs, wires, and fuel pump again just for good measure.
    Thanks a ton!
    Brent
  2. #2 Re: Help! Gas Mileage Dropping
    Clean the MAF sensor yet?
    Any SES still?
    Maybe faulty o2 sensors?
  3. #3 Re: Help! Gas Mileage Dropping
    St. Louis
    What type of spark plugs did you use? Using 91+ octane I hope? Cat clogging up?
  4. #4 Re: Help! Gas Mileage Dropping
    SWPA
    Are you using the DIC info, or actually calculating mileage? My DIC is off by 1.5 mpg or more.
  5. #5 Re: Help! Gas Mileage Dropping
    HUDSON
    A faulty, or out of range ECT sensor (engine coolant temerature) will hurt your fuel milage. You state in your post you changed everything, but did not state anything about the sensors. It would be a good idea to check and make sure it is working properly, even thou you your not getting a DTC for it.
  6. #6 Re: Help! Gas Mileage Dropping
    Willoughby, Ohio
    3800? problem? its a sensor...
  1. Procedure for dropping the oil pan on GTP?
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2011, 06:18 PM
  2. Rpm's dropping
    By 2001GrandPrix GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2011, 04:20 AM
  3. dropping subframe
    By Jakegday in forum General Tech Discussion
    Last Post: 10-01-2010, 09:59 AM
  4. Dropping some Serious cash
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 11:08 PM
  5. Dropping cradle
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2009, 11:38 AM
