Thread: engine knocking
Results 1 to 8 of 8
  1. #1 engine knocking
    Aug 2008
    oharr
    Hey everybody I need some help with my car...well to begin a couple of days ago the engine started rattling well I found out it was the pulley of the AC compressor I was planning on changing the bearings but today as I was driving to work the whole car started shaking and as I pulled up to a stop sign I pressed on the gas but it didn't wanna go it was going real slow I pulled up to my friends house to check it but it wouldn't turn on anymore .......any help would be greatly appreciated thanks
  2. #2 Re: engine knocking
    does it crank but not start?
    do you know if you had any knock (kr) when you were last running it really hard?
    we really can't tell anything unless you give us more information.
  3. #3 Re: engine knocking
    Jan 1970
    Maquoketa, Iowa
    Did you check the belts?
    Flexplate?
    more info.
  4. #4 Re: engine knocking
    Aug 2008
    oharr
    Well the belts r good I replaced them about 2 months ago and the engine does crank but it doesn't turn on and the flexplate I don't know which one that is and I don't have the machine to check for kr
  5. #5 Re: engine knocking
    NE Ohio
    spun bearing? hows the oil look?
  6. #6 Re: engine knocking
    Aug 2008
    oharr
    Well what's a spun bearing? Um I'm still learning evetthing of the motor and the parts so if yall can bear with me on that id really appreciate it and the oils good I changed it about 2 months ago
  7. #7 Re: engine knocking
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    wow it could really be ALOT of things, if you need the car fixed now, just have a machanic look at it quick ($80) not cheap, or maybe someone on here that knows alot lives around there.
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  8. #8 Re: engine knocking
    NE Ohio
    it was good 2 months ago, but what does it look like now?
  1. Engine Rpm
    By 04 GTP COMP G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 12:36 PM
  2. Now that the engine is out....
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2008, 01:13 AM
  3. mods for engine
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2008, 07:43 AM
  4. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  5. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
