Thread: injector options
Results 1 to 6 of 6
  1. #1 injector options
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    i was curious if there were higher flowing injectors from other vehicles that will work on our cars, without modification, basically "plug n play"
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: injector options
    Ford injectors...from the Cobra or Lightning...
    Called green tops.
    42 lb'ers.
    Work like a champ, and would probably help your setup since you need to be running a dumb sized pulley on that NIC cam.
  3. #3 Re: injector options
    According to GPF.
    Anything goes in, just change IFR then you're done.
    According to the rest of the world, not so much.
    Green tops are just as cheap in design as lucas injectors. cobra injectors are skinny blues, lightings are the green tops.
    Skinny blues have an odd spray pattern that wouldnt be so useful in our engines. See youtube.
  4. #4 Re: injector options
    Mar 2012
    Dallas
    Called green tops.
    42 lb'ers.
    damn was hoping for cars i could easily find in a junk yard. snag the injectors and bring them to school to be flow benched and sonic cleaned.
    According to GPF.
    parden my ignorance, but what do you mean by change the IFR?
  5. #5 Re: injector options
    It'd have to be something that makes quite a bit of power per cylinder.
    Most things will have injectors in the 20 lb range. Less than your stockers.
    IFR is injector flow rate.
  6. #6 Re: injector options
    Mar 2012
    Dallas
    that answers my question about if i needed to change my tuning for higher flowing injectors.
  1. need options
    By redlinepontiac in forum Off Topic Discussion
    Last Post: 12-31-2011, 11:00 PM
  2. H/U options
    By BLWNPontiacs in forum Audio, Security & Visual Electronics
    Last Post: 09-28-2011, 09:40 PM
  3. Rad Options.
    By matt5112 in forum General Tech Discussion
    Last Post: 07-28-2011, 10:15 AM
  4. TB options
    By 4drgt in forum 04+ Specifics
    Last Post: 09-12-2009, 03:14 PM
  5. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
