Thread: Full glasspack/steelpack exhaust?
Results 1 to 16 of 16
  1. #1 Full glasspack/steelpack exhaust?
    Feb 2008
    I'm considering going with a glass/steel-packed muffler and res setup. I got an opportunity to test a bullet steelpack muffler from a friend's mustang for a few days and liked the sound of it (bolted on to the DP, then dumped under the back seat) but want to keep my hearing. So, what if I used something like that as a res and then again as mufflers?
    Any experience with similar setups or suggestions?
  2. #2 Re: Full glasspack/steelpack exhaust?
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    i would like to know the same cause i wanna do glasspacks
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  3. #3 Re: Full glasspack/steelpack exhaust?
    May 2008
    McHenry IL
    DO IT!! i heard 1 it sounded nice it had headers and just a sright pipe with 2 glass packs it was nice!
  4. #4 Re: Full glasspack/steelpack exhaust?
    Aug 2008
    Iowa
    thats what i plan on with out the headers yet. right now its straight pipes and im getting bored
  5. #5 Re: Full glasspack/steelpack exhaust?
    Feb 2008
    As soon as I get the opportunity to get everything together for the setup, I'll do it. Any brand suggestions? I'm thinking of the summit glasspacks. They're cheap.
  6. #6 Re: Full glasspack/steelpack exhaust?
    Aug 2008
    Iowa
    either that or go on ebay and get the ones on there i forgot what they were but they were like 20 plus shipping (could be crappy glass packs) but you never know
  7. #7 Re: Full glasspack/steelpack exhaust?
    dont take off your mufflers. just get a glasspack to go in place of the resonator.
    find the biggest one you can (length).
  8. #8 Re: Full glasspack/steelpack exhaust?
    Aug 2008
    Iowa
    how would a glasspack res and borla muffs work? thats my new idea
  9. #9 Re: Full glasspack/steelpack exhaust?
    would sound good. borla's are the best sounding on these cars besides stock.
  10. #10 Re: Full glasspack/steelpack exhaust?
    Feb 2008
    You don't think a full glasspack setup will sound good, Bio? There's a slight problem with my stock exhaust setup, though. I had this bright idea a few years ago that drilling a few holes through the casing of the stock mufflers would give me a little bit more volume and wouldn't cost me the money of new mufflers (very stupid idea, BTW). The downside to that is, now, with my cam, it doesn't just sound louder. When I accelerate, it is obvious that I've drilled those holes and sounds like I have an crappy exhaust leak (idle sounds nice, though). I don't want to repair them or replace them with other stock mufflers because I do want more volume out of my exhaust system.
    How big of a difference is there, actually, with just replacing the stock res with a glasspack?
  11. #11 Re: Full glasspack/steelpack exhaust?
    no. straight exhaust on these cars are garbage. you need some kind of muffler for sound definition.
    a glasspack will flow better than the stock resonator and it will also give a little more growl to it and still keep the rasp at bay.
  12. #12 Re: Full glasspack/steelpack exhaust?
    Aug 2008
    Iowa
    mine does sound to bad, but when it starts to rasp it really rasps.
  13. #13 Re: Full glasspack/steelpack exhaust?
    Donating Users
    W-S, NC
    I have glasspacks in place of the mufflers...YouTube - 99 GTP with dual Thrush glasspacks. If you dont have the res,your gonna have more rasp, and its gonna be hella loud depending on what size g-packs you get. Mine above has some rasp and I still have the res. in place. Im curious how its gonna sound after Sat. when I put my 2.5 dp on and do a U-bend delete. Ill try and get a sound clip or 2.
  14. #14 Re: Full glasspack/steelpack exhaust?
    Feb 2008
    That sounds pretty good. I think that'll be the route I go. I'm looking at the Summit brand stuff just because it's a bit cheaper and have heard good things about some of Summit's other mufflers. I'm thinking 3" for the res and a pair of 2.5" for the mufflers. Each of those is a size larger than the piping, but I've heard that larger gives a deeper tone. Should I stick with the factory sizes or will the larger ones work like I'm wanting?
  15. #15 Re: Full glasspack/steelpack exhaust?
    Jul 2008
    sumter,south carolina
    heres mine...catback flowmaster with dual rolled tips with u bend delete
    02 GTP with mods 05 GP for DD
  16. #16 Re: Full glasspack/steelpack exhaust?
    Donating Users
    W-S, NC
    Quote Originally Posted by DanGTP View Post
    The ones I ran were 2.5 inch, then I heated the end of the glasspack and put my stock tips back on it. Personally id do the same size through-out just to keep the exhaust flow smooth. Its like a lot of people ive seen that run a 3in downpipe into a stock exhaust. Your gonna have some backpressure due to the larger amount of air going from the downpipe into the smaller size pipe.
  1. gas gauge stuck on full
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 02:10 PM
  2. slp exhaust
    By hotshot in forum General Tech Discussion
    Last Post: 08-27-2008, 10:44 PM
  3. should of bought the full size ic
    Last Post: 07-20-2008, 07:27 PM
  4. exhaust
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2008, 11:06 AM
  5. exhaust
    By crshoveride in forum Off Topic Discussion
    Last Post: 03-13-2008, 02:40 PM
