Thread: Coolant Leak from EGR Tube, Please Help.
Results 1 to 20 of 29
  1. #1 Coolant Leak from EGR Tube, Please Help.
    Jun 2011
    Oklahoma
    I have a coolant leak coming from my EGR Tube, connected to the LIM. (Right where the bolt and tube connects at the manifold itself). Its really odd for it to be leaking from that area. Im pretty sure that section is for the exhaust gases. Im thinking the LIM is cracked right in that area... Hopefully my heads aren't cracked... I replaced the LIM gaskets to the Felpro Aluminum set thinking that the rubber sides were the "fail spot", but I guess I overlooked it, cause I put everything back together to find that the problem wasn't fixed. I also checked the maifold for any cracks or weird spots before putting it back together, but I didnt find any, so maybe its one of those awesome hairline cracks that you cant see by eye. Is there any way to have it inspected/inspect it yourself for cracks...? off the car? Besides the obvious, looking at it, cause I sure didn't see any cracks. My engine oil is not mixed, Im not blowing out water from the exhaust. But is there a possibility for a cracked head as well? Its really odd. I repair most of my vehicles issues, and I've never seen this happen before. If anyone can help to determine this issue, I would really appreciate it, and see what my next step should be.
  2. #2 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    Did you replace the o-rings that seal between supercharger and LIM?
    Also, the bolt that hold the EGR tube flange may go into the water jacket. Make sure there is thread sealant on the bolt before you put it back in.
  3. #3 Re: Coolant Leak from EGR Tube, Please Help.
    I grabbed the NA motor UIM failure before having a chance to notice the section you posted this into. I would doubt you have any head or LIM issues beyond a gasket or o-ring. Most likely when you put the charger in place, one of your o-rings moved. Being that you don't mention your year, I'm guessing 97-03 as the o-rings were simply sitting in place and not held or molded into the gasket like the 04+ years.
    Only other thing I'd think it could be would be the end seal on the LIM, it's a little cover under the TB with two 8mm bolts. This cover
  4. #4 Re: Coolant Leak from EGR Tube, Please Help.
    Jun 2011
    Oklahoma
    I did replace the two yellow O-rings that are seated under the Supercharger. I also put thread sealant onto that bolt that holds the EGR tube to the LIM. The cover thats on the LIM, where the EGR tube meets the LIM has a new gasket and high temp RTV on it, it is not leaking from there. I saw it literally spraying out from the bolt flange of the EGR tube. (top portion of the flange) Its not exactly where the bolt meets the LIM, its where the pipe slides into the LIM. The top of that is where is praying out. The car is a 98 GTP. Im gonna just remove it again, and see if theres a hole in that portion of the intake. Ill post some pictures of what I find.
  5. #5 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    Grandprix27
    Not doubting you - but this one of the strangest problems I have ever hear of with the 3800. Are you sure it's not spraying from the gasket between the SC and the LIM?..as Bill has alluded to previously?
    When you take it back off clean it real good and run some 220 grit sand paper in the EGR port and see if you see a crack. If it's actually spraying it should be quite obvious.
    I can't wait to see the pics.
  6. #6 Re: Coolant Leak from EGR Tube, Please Help.
    Jun 2011
    Oklahoma
    Yes 100% sure. Trust me it is very weird for it to be spraying from there. Also I just removed that tube, and guess whats sitting in there? Antifreeze. I'll try to snap a picture of it.
  7. #7 Re: Coolant Leak from EGR Tube, Please Help.
    It's obvious if it's coming from there, that it'll be full.
    I'm also in for the picture of the hole in that area. Never heard or seen that before. My first instinct would be that it's pushing down from one of the yellow o-rings being sligntly out of place. They are close by and could to that.
    Another misc item, the EGR bolt isn't tapped into a cooling port. It shouldn't require sealant. The gasket on that end cover should be installed dry. But that is more of less installer choice.
  8. #8 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    Yea, I just looked at mine and it is definitely a blind tap...good to know.
  9. #9 Re: Coolant Leak from EGR Tube, Please Help.
    Chuck...you know how it goes. Just ask.
    Most likely I've been there, broken that or at least checked it out.
  10. #10 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    You can't post pics from your PC...only from a url like photobucket.com.
  11. #11 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    When you put the EGR tube flange on did you use the original (very short) bolt? If you used a longer bolt it may have punched a hole or cracked the manifold. Check for cracks or damage to the blind tap for the bolt.
  12. #12 Re: Coolant Leak from EGR Tube, Please Help.
    Jun 2011
    Oklahoma
    Okay well after tearing it down 4 or 5 times and putting it all back together, I cleaned that hole out, by eye I cannot see any crack, just a few scratches. Man its been a real ****ty and stressful day. Im definately gonna need another Supercharger Gasket from taking it apart so many times. This story is gonna get a lot weirder... Remember this Upper and Lower Intake has all brand new Felpro gaskets and new O-rings. (Aluminum LIM Gaskets). Bare with me while I try to explain... The first time out of 5 attempts today, it was coming from the EGR Tube----LIM connection. Took a picture with the coolant in the hole, then cleaned it out, and took a picture of that too. Ill post after I get done explaining. Put it all back together, then it starts leaking from the cap on the Lower intake (right below the EGR tube). New gasket is in there with High Temp red RTV sealant. Well take it back apart, replaced the new gasket with another one and more RTV. Hahahaha... this is where **** gets weirder... Put it back together, starts leaking from the EGR tube again, not the cap this time. ?!?!?! Take it back apart, O-rings from Supercharger are in place nothing has moved. Put RTV on the O-rings of the Supercharger, just in case. check that damn hole again... NOTHING! No crack, no holes! Put it all back together. Starts leaking from the Cap again. Nothing is coming from the EGR tube, it is completely dry. Take it back apart Supercharger gasket has torn by the bolt holes at this point... oh well its not important because its just by the bolt holes... Looked at the Supercharger to see if the coolant holes might be crack...mmmm...NO! Replace the gasket to the cap again, and literally inspect those two water jacket openings, no obvious holes or cracks... This is literally blowing my mind and making me feel like an idiot for doing all this removing and putting back together of the engine. Finally get it all back together, then it leaks from the EGR Tube. Im absolutely dumbfounded, the only thing I can possible think of is, maybe with the engine and intake warming up that the crack opens up from the heat, cause heat causes things to stretch...right? maybe its such a small crack, that you cannot see it with just your eyes. maybe needs to be X-rayed or something (Non-destructive testing)? Yeah something like that. Or another option is maybe a blown head gasket, maybe water is somehow pushing through somewhere, and its causing ths nonsense. Looked at my oil, and it looks alittle mixed, but it maybe because of my taking it apart so many times that water gets into my oil by accident. No white smoke or water comes out of the exhaust....YET! I havent even let the temp run past 195*, I always shut it down, as soon as the leak starts. So im kind of ruling the head gaskets out, although it could be a possibility. So...besides all that, my day sucked. How was yours? lol. Sorry i had a little of a rant going, I'm just frustrated at this point. If anyone has any idea please let me know. I have another spare LIM that I will put on tomorrow and see if anything changes.
    Here is a picture with coolant in the hole:
  13. #13 Re: Coolant Leak from EGR Tube, Please Help.
    Jun 2011
    Oklahoma
    Picture of cleaned out EGR Hole, Dont see any cracks, or holes, just a few scratches:
  14. #14 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    Is this where the leak is? Why are your pictures from the top?
  15. #15 Re: Coolant Leak from EGR Tube, Please Help.
    Take the o-rings out.
    1. It's not a head gasket. You are no where near the head gaskets. Please understand, it's not a head gasket.
    2. The TB to SC gasket. Have you replaced that? Please check it. It can allow coolant into the charger (which you would see inside the charger and then down into the elbow.
    Damn...that hole is close by
    If you had any external leak from it as well, that would definately be able to look like the end cap is leaking. It's not an easy area to look for a leak.
    3. Take the o-rings out and ensure the recesses are clean. Double check the bottom of the charger to be clean.
    There is something small that is causing this issue. I'm thinking its a gasket or a dirty gasket surface. I highly doubt it's a cracked LIM. I am positive from your description and issue, it's not a head gasket.
    All of the gaskets you are working with, should be installed dry. Meaning, no RTV. As you take it apart again today. I'd suggest cleaning all that stuff off and going at it fresh, clean and dry.
  16. #16 Re: Coolant Leak from EGR Tube, Please Help.
    Chuck, his pics are from the top, because wiithout taking the LIM off...his exhaust is a little too close to get a good pic from the side.
    Now c'mon on board with my "theory of leakism".
  17. #17 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    Bill - if it were leaking from the gasket or the o-rings it would get pulled in (at engine idle negative pressure) and blown out the exhaust, no? That area is only under positive pressure when the SC is creating boost.
    I see what you're saying about the TB gasket and that could be it.
    He says it's squirting out from the EGR tubing flange. This is completely baffling.
  18. #18 Re: Coolant Leak from EGR Tube, Please Help.
    The squirting might be from the boost being generated by the SC, being recycled through the bypass and creating some pressure, which would flow into the EGR tube area as well.
    Chuck: Can't back a buddies theory, it's ok... I see how you are. wink wink
  19. #19 Re: Coolant Leak from EGR Tube, Please Help.
    Apr 2009
    Fort Worth TX
    This sure isn't another "leaky coolant elbow" thread. This is new and exciting. LOL
    OK, I'll back that theory...but only cause it's yours.
  20. #20 Re: Coolant Leak from EGR Tube, Please Help.
    This is exciting? We gotta spring you outta the nursing home more often.
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  3. bad coolant leak
    By johnfolks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2011, 04:30 PM
  4. Coolant Reservoir Tube?
    By Pagss in forum General Tech Discussion
    Last Post: 10-19-2010, 01:49 PM
  5. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
