Re: Good cost alternative source for high octane fuel.......Race Gas...on the cheap..
ITHURTZ
they all need to be tuned with any mix, its pointless otherwise
then why wouldn you just get a good tune on 92 octane? +1 or 2 octane from 92 wont be that much of an improvement if you have a good tune on the 92....
sure it will help a little but not worth the power to money imo...
and im sorry but unless you have a serious hookup in the long run ( unless your race gas is like $10 a gallon ) the paint thinner is still not cheaper...
ITHURTZ
you mix it.... for mixing with 92 octane
XYLENE |
resultant octane rating |
10% |
94 |
20% |
97 |
30% |
99 |
Buy it in 5 gallon buckets its cheaper or 55 gallon drums way cheaper
Mixing E85 with 93 works to. I only know 1 place with e85 and thats about 25min away.
mixing 10% only gives you an octane rating of 92.8
mixing 20% only gives you an octane rating of 93.6
mixing 30% only gives you an octane rating of 94.4
a good blend of "E42.5" would be comparable to 98-100 octane.... Maybe not so much in a n/a car but in a boosted application it would be at least that.
Nixon
race gas is $8/gal here
It was nearly $8 when they closed KCIR...
chrisatpsu
I dunno what your mixing
