Thread: 160 or 180 degree thermostat??
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41 Re: 160 or 180 degree thermostat??
    Omaha, NE
    If you don't need a 180, STICK TO STOCK!
    89% of people running 180* Tstats don't need them. Stock temp is set to run at 210* for a reason.
  2. #42 Re: 160 or 180 degree thermostat??
    Apr 2011
    Tally, FL
    Is timing being pulled over when the ect's are 200 degree's?
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    I thought it was 91%? Did I miss the memo??
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  4. #44 Re: 160 or 180 degree thermostat??
    But it is.
    But it isn't.
    Mileage actually didn't change one bit with the EGR deleted, running a 180* T-Stat in the silver car.
    I've ran a stock T-Stat, a 180*, a drilled 180*, and a non-drilled 160*...if anything I hated the stock temp T-Stat because these cars don't like getting hot anyways...so whats the point in helping out that aspect and creating more potential for heat soak, melted wires, dry rotting engine parts, warped plenums...etc.
    Please, continue with your 195* theory, where every car should run a higher temp thermostat because "It needs a stock temp".
    Bullsh1t.
  5. #45 Re: 160 or 180 degree thermostat??
    Jun 2012
    South west Michigan
    Everyone has some great ideas here but I would stick with the stock temp. unless you have a re programed computer? The drilling of a small hole in the thermostat is an OLD trick and VERY good one ….this was before they started putting dent in the valve to let the air bubble out after replacement……..BUT still none the less the drilling of a small hole is a good idea.
    What I did on my 1999 GT was add a fan switch so that at any time I could turn on both fans …this works great …its all built into the harness and I just plugged it in and ran the on off switch to the dash and added my own bright LED so I knew when it was on.
    I also have a totally reprogrammed computer that keeps the fan on for 5 minutes after I turn the car off …
  6. #46 Re: 160 or 180 degree thermostat??
    The Boss Iceman6669's Avatar
    Jun 2011
    While I will admit to having NO first hand experience with changing the TStat to a cooler one, I DO understand the reason to do it.
    This is MY understanding of it.
    It is all in an attempt to reduce/eliminate KR. Why is KR created? Because of High INTERNAL CYLINDER TEMPS. SO by running a cooler Tstat you can keep the water in the water jacket cooler and thus keep the cylinder walls cooler. Helping to remove some of the heat at THAT point. IMO a 180* or cooler is not needed UNTIL you TUNE AND PULLEY DROP. Going down in pulley sizes creates more heat, so you need to do something to counter that heat to reduce KR. BUT just like all the other supporting mods NOT EVERYONE may need it. One car may run just fine on a 3.4" setup with a 195* TStat, where as another car may knock a little more. So in the car that knocks a little more just reduce the heat in the cylinders by cooling the water jacket a little more and you can help combat the KR.
    As far as it hurting your motor or gas mileage, I again can not speak from first hand account but I have heard it will hurt your mileage. BUT I have never heard of it doing ANY damage to your motor. I have ran with NO TStat in my truck for YEARS and had no problems with the motor.
    The only reason I can even believe that it would hurt your gas mileage is because of the old rule that I learned long ago.
    COOL = MORE POWER
    HOT = BETTER MPGs
    Anyway that is my take on it and my 2 cents.
    2011 F-150 Yote powered
  1. Thermostat?
    By Pure2sin in forum General Tech Discussion
    Last Post: 06-08-2011, 08:33 PM
  2. 180 degree thermostat
    By IGGYS 2008 GXP in forum 5.3L V8 (LS4)
    Last Post: 05-07-2009, 09:47 AM
  3. GTP Question New To The 90 Degree Motor
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2008, 08:15 PM
  4. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
