The GTP has been leaking oil for a while now. It's definitely coming from the timing cover at the crank seal. The problem is that we've replaced the seal 4 times already and put a brand new balancer too and it still leaks.
We took off the timing chain cover today to see if there's anything else wrong with it and this is what we found:
The cover seems to be worn from the inside. Everything else is in perfect condition, all seals were replaced a few months back when we swapped camshafts.
Now my question is if this wear on the inside of the cover can cause for some extra oil to leak into the seal? We really don't know what to change besides this part.
