Thread: weird glitch with my rpms
Results 1 to 7 of 7
  1. #1 weird glitch with my rpms
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    so while scanning the hptuners sees a spike in rpms and the car shuts down for a secong...then normal then glitch....kind of hard to explain but i have changed the crank sensor, th computer, the ign module. i cant figure out all the things that could affect the rpm like this. any1 else had this issue?http://www.facebook.com/photo.php?fb...type=1&theater
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  2. #2 Re: weird glitch with my rpms
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    It's not a "glitch", your car isn't a computer program.
    Change your cam position sensor, crank position sensor, and check the harness that goes to both of these sensors. It sits behind the serpentine belt and sometimes gets chaffed.
    For all your 3800 needs:
  3. #3 Re: weird glitch with my rpms
    Apr 2009
    as already stated i did the crank sensor. today i did the cam sensor. inspected wires. they look great...i also inspected thm when i had the harmonic off when i changed the crank sensor...all wiring is in good condition with nothing bare or touching anywhere it shouldnt be......so any more ideas for this rpm spike and then the thing goes to shut down...i am about to mess with the knock sensors.....im lost. after this im gonna try changing the ign control module again..this will be the third one.....
  4. #4 strange rpm spike
    Apr 2009
    hp tuners software caught the glitch i am speaking of. the car wants to shut down when this happens. its an l26 top swap. no engine codes, i changed the crank sensor, the cam sensor, the ign control module, and computer. im not sure what else deals with rpms....when this happends its under boost..normal driving it does not do it. also seems like sometimes it wont do it. mostly does it tho. in the tune we have got kr almost completely gone maybe a blip here and there. traction control is disabled. we set the rev limiter from 7000 rpms to the max hp will let us 8000 rpms. either way it some how thinks its over revving and shuts down. obvously in the pic in 2nd gear at 48mph i am not at 8000 rpms but something is telling the pcm that it is... any ideas???? click link to see pic
    Facebook
  5. #5 Re: weird glitch with my rpms
    Don't make multiple threads for the same issue.
    Also that picture is private.
    Use something like photobucket.
  6. #6 Re: weird glitch with my rpms
    Apr 2009
    well where would u like me to put it because at first i thought it was a tune issue now i think its with the engine so i want it in two different places so people see it
    turtle boy =/
  7. #7 Re: weird glitch with my rpms
    And then the people who only see one thread won't know the processes you've put the car through and any other issues that may or may not be presenting themselves.
  1. rpms bouncing around weird
    By gtcoup in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2011, 10:46 PM
  2. No RPMs..?
    By GTBabyGirl in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2011, 07:46 PM
  3. On star glitch
    By NashGT02 in forum General Tech Discussion
    Last Post: 03-04-2011, 07:41 PM
  4. RPMs...??
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 11:47 PM
  5. is this a glitch?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-18-2008, 01:17 PM
