Thread: Non accurate gas gauge after fuel sending unit replacement
Results 1 to 7 of 7
  1. #1 Non accurate gas gauge after fuel sending unit replacement
    Apr 2012
    860 CT
    hey guys,
    yesterday I replaced my fuel sending unit on my 01 gp gt.
    seemed like an easy job. replaced the sending unit with the $20 one I got off eBay.
    when I was done, the gas gauge dropped low, then after driving a little bit i was on E, which I thought was accurate judging by how much i drove beforehand. i went to fill up, $64 later, and had a full tank and the gas gauge showed it.
    however, i have since driving 40 miles and the gas gauge still shows im on full even though we all know im not.
    so am i just being paranoid and its going to drop soon or is there something else wrong causing the gas gauge not to be accurate?
    any help is greatly appreciated!
    thanks!
  2. #2 Re: Non accurate gas gauge after fuel sending unit replacement
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    On my 04 gp gt1 I go about 60ish miles before my needle drops to show that I don't have a full tank. It will probably drop soon.
  3. #3 Re: Non accurate gas gauge after fuel sending unit replacement
    Give it time.
  4. #4 Re: Non accurate gas gauge after fuel sending unit replacement
    Apr 2012
    860 CT
    it started to drop today!
    thanks guys
  5. #5 Re: Non accurate gas gauge after fuel sending unit replacement
    Something you will prolly notice in do time is that the gauge likes to slowly drop until you hit about 3/8 tank, then it will drop faster. My car has always been like this after I swapped my sensor out, even my dads mazda is this way.
  6. #6 Re: Non accurate gas gauge after fuel sending unit replacement
    Apr 2012
    860 CT
    alright thats good to know, thanks!
  7. #7 Re: Non accurate gas gauge after fuel sending unit replacement
    Jan 1970
    Maquoketa, Iowa
    I bent my float rod when re-installing and its off a bit. You could have tweaked it one way as well, it's not going to recalibrate itself when it's moved.
  1. Getting 2.5 volts at fuel/sending unit....how come?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 08:39 PM
  2. Fuel Gauge Not Accurate
    By Connors33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2009, 09:07 PM
  3. fuel sending unit
    By stanggreg90 in forum General Tech Discussion
    Last Post: 08-01-2009, 06:23 PM
