Thread: Do I have Engine knock?
Results 1 to 7 of 7
  1. #1 Do I have Engine knock?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    So I have posted in here b4 about how my car will "knock" or rumble at random interverals (about once every 3 seconds) in park or neutral (not drive) which vary in strength.
    Now today b4 work I let the car warm up a minute while I had a smoke. I popped the hood just to take a look and I began seeing the engine actually shake (doesnt look to be to normal). I felt the dog bones and I could feel the exact rumble.
    What does this sound like?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Do I have Engine knock?
    Barksdale AFB, LA
    Knock can be heard, but usually isn't. And you're definitely not knocking at idle. I have yet to hear my knock. Classically, knock is known as "ping" as it sounds more like a ping noise.
    The only way to see if you have knock is with a scanner. What you're noticing (a "bumpy" idle) is common to all 3800s.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Do I have Engine knock?
    Bartlett, IL
    Quote Originally Posted by Sabrewings View Post
    Cool, there are definettly no "ping" noises.
    So no engine mounts are dog bones need to be replaced?
    How To: E-Brake Pwn
  4. #4 Re: Do I have Engine knock?
    Barksdale AFB, LA
    Why would they need to be replaced?
  5. #5 Re: Do I have Engine knock?
    Donating Users blowfishRus6's Avatar
    g.a.
    random miss fire. my car also runs ruffer with lower quality gas. good gas and my car does not do it near as bad as it used to
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: Do I have Engine knock?
    Bartlett, IL
    lol thats a funny avatar dude
    How To: E-Brake Pwn
  7. #7 Re: Do I have Engine knock?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    To answer you question, "do I have engine knock?" Probably, but that's not uncommon on a completely stock GTP either.
    Anyway Sabrewings is right a small slightly detectable stumble is normal, but you shouldn't see much movement on your tach on your tach, if any at all.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  2. Knock Sensor
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:51 PM
  3. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
  4. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  5. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
