Thread: Midnightblue rebuilding his engine once again!!!!!
Results 1 to 8 of 8
Threaded View
  1. #1 Midnightblue rebuilding his engine once again!!!!!
    Banned
    Sioux Falls, SD
    So on my way home for lunch going about 90, then my low oil presure light came on......right away i was like I put some oil i had in the motor so i could limp it home only 2 blocks away. I jacked up the car and oil it coming from the oil neck for the filter, i lost a rod cause i can here it banging around when i crank over the motor........so here come the new build
    1. JE Forged Pistons .20 over
    2. ZZP 4340 H-Beam Connecting Rods (Roating assambley will be balanced)
    3. 8 Rib SFI Balancer (not sure)
    4. XP Cam
    5. Rollermaster Double Chain
    6. 60 lb injectors
    7. Intercooler
    8. 3.2 pulley
    9. ARP mains and rod bolts
    10. Port the heads more
    11. Have block heat tanked, decked, and new freeze plugs installed
    12. All new bearings
  1. Rebuilding a 3800
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2011, 12:58 PM
  2. Miker56, or MidnightBlue = Scammer?
    By RegalGS98s in forum The Rant Forum
    Last Post: 06-27-2011, 01:36 PM
  3. Rebuilding an Engine, Steam Cleaning Internal
    Last Post: 02-07-2011, 10:27 PM
  4. rebuilding M90 snout
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 08:52 AM
  5. Rebuilding L67 motor
    By theboss98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 12:38 AM
