Re: help me identify this sound please!
it was definately not the idle, the idle itself is very smooth.
the noise is gone. it was either the spark plug wires or writing to the pcm that did it, cause those are the only things that changed. or it was something rubbing/hitting and it wore itself out.
i've got plugs and wires on their way from ZZPerformance, I'm pretty sure that's the problem. No coolant is leaking, and the mounts looked good. I should probably should've ordered new mounts though just to upgrade them.
