Thread: can someone explaine this to me?
Results 1 to 20 of 27
  1. #1 can someone explaine this to me?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    ZZPerformance - 304 Stainless Power Log #ZZ-304PLOG
    this is just the front part of the headers right? can i just bolt this on with the stock headers? what will this do in terms on performance?
    thanks for the help
  2. #2 Re: can someone explaine this to me?
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    http://www.grandprixforums.net/safel...car-17482.html
    Check #6
    And yeah, its just the manifold.
    The evil LG8 still refuses to die.
  3. #3 Re: can someone explaine this to me?
    Oct 2011
    Michigan
    ok well my car is just a daily driver not a track car i just want it to be the best daily driver it can be with out to much work gotta spend time with the other toys, do you think i should do this instead of doing cheap headers?
  4. #4 Re: can someone explaine this to me?
    No matter what you do, the U-bend has to go, and the manifold is a terrible design for even mild performance. Speed Daddys will take care of both.
  5. #5 Re: can someone explaine this to me?
    Oct 2011
    Michigan
    i really dont want to put the time/money into full headers, do you think this and a u bend delete will be enough?
  6. #6 Re: can someone explaine this to me?
    Jan 2012
    Philadelphia
    Quote Originally Posted by asite57 View Post
    be enough for what exacaly? i have a 2 1/2" catless DP with a glasspack and stock mufflers, a plog is on the way i just didnt wanna go through the hassle and time of installing headers i might upgrade once i graduate school and start working more
  7. #7 Re: can someone explaine this to me?
    Jul 2011
    B-Town, PA
    between the PLOG and the ubend delete and porting the rear manifold to match you should just suck it up and spend 200 bucks on the SD headers and be done. I antagonized over this exact issue and went headers on my Park Ave Ultra. no regrets.
    SMGPFC Member # 569 - Mad Monkey Approved!
    New Ride - 2012 CTS-V Coupe 6spd - Black/black, Recaros. Stock for now.
  8. #8 Re: can someone explaine this to me?
    Oct 2011
    Michigan
    its such a tough decision im not looking for major gains im just looking for an upgrade over stock
  9. #9 Re: can someone explaine this to me?
    SE Level Member tu8i1o7's Avatar
    Siuox Falls, SD
    Why spend 150 on a single bank pipe, while still using a stock rear manifold, downpipe, and U-bend. Take the extra $50 and the extra ~2 hours and do headers. They look better, flow better, and aren't too complicated to install. Hardest part would be a little welding, but you can even just use clamps.
  10. #10 Re: can someone explaine this to me?
    This^^
  11. #11 Re: can someone explaine this to me?
    new britain, ct
    headers wont drastically change your performance lol. they help the flow. the better the flow the better the mpg's as well
    07 Black GXP.
  12. #12 Re: can someone explaine this to me?
    When i put my headers on i knocked 4 seconds off my 0-100 times.
  13. #13 Re: can someone explaine this to me?
    Oct 2011
    Michigan
    so you all say that this is a better buy? 97-08 PONTIAC GRAND PRIX GTP 3.8L HEADER 03 04 05 06 07 | eBay
    Bunnell, FL
    So are the headers a better deal at 201$ shipped vs the zzp plot ag 150$ plus shipping. So basically about the same after shipping....
    Android Fire
    I'm a Sex Offender
  15. #15 Re: can someone explaine this to me?
    Oct 2011
    Michigan
    enough for my daily driver, i do drive fast though
  16. #16 Re: can someone explaine this to me?
    Dont mod your daily driver.
    The PLOG is such a waste, $150 for that plus shipping, then you still have to remove the crappy stock downpipe and ubend thats another $120 if you go with the cheap zzp dp. Your now at $270 before shipping and you still have the stock rear manifold. Just buy headers and save your self the trouble.
  17. #17 Re: can someone explaine this to me?
    Definitely mod your dd it makes the trip to work so much more fun.
  18. #18 Re: can someone explaine this to me?
    I have a plog and DP. Only because..they fell into my garage for the right prices. Things you can expect with these parts: Plog will crack due to inferior welding and the manifold to Dp gasket will leak.
    Jan 2009
    Tallahassee, FL
    I have a DP and PLOT just because I bought them right before the cheap Speed Daddy headers came out, so I'm stuck with them lol.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  20. #20 Re: can someone explaine this to me?
    Oct 2011
    Michigan
    Ok ill go with the headers (and thanks bill I found that excellent write up) but I definitely plan to lighty mod my DD why not right?
