Thread: 1998 GP GT Top Swap Questions
Results 1 to 9 of 9
  1. #1 1998 GP GT Top Swap Questions
    Mar 2012
    Rittman, ohio
    I got my first GP the other day for 300 it cam with a L67 and HD trans out of a Regal i have the ecu harness and all but now for my questions. Did i get a good deal.
    They guy did not know that the motor he bought threw a rod. so since the N/A is more common to find in a junk yard. i figured that i would use the top swap route. are the front covers the same between th N/A and S/C ?
    I am thinking of doing a mild build in the process.
    i have a used E3 plus in the trucks that i loved. will they work in this motor. Planning on running MSD wires. A 160 degree tstat. i want to run a VS cam also was looking at the conversion harness that they sell as well. was planning on having ZZP tuning the computer as well. was going to replace the worn coupler with the zzp one. and at this point should be looking for headers. i was looking for a cheap solution for that. would like to pro the pulley size at this point but not sure how far to drop it. was thinking of running a cone off the end or the TB. should i be looking to underdrive the water pump and the alt. im looking for a fun car that is reliable as it will be the wifes car and she wants a fast car. did i over look anything?
    \also i have read that they should be nothing shinny with rotors mine are a little shinny at the very edge of the rotors is that ok?
    which head gaskets should i run im leaning towards the MLS at .051 think as well i was gonna run ARP head stud kit but i was tempted to run the cheap gaskets but over time i would like to do a Gen 5 Intercooled in time
    ZZPerformance - Engine Gasket Kit #ZZ-ENGK
    Comp Cams - VS Cam #COMP-3311/3303-115+2-VS
    Easy Performance - L67 Swap Kit #EP-L36-L67SWAP
    ZZPerformance - Supercharger Coupler #ZZ-SCCPLR,
    Cometic - Cometic Multi Layer Metal Head Gaskets #CM-
  2. #2 Re: 1998 GP GT Top Swap Questions
    No e3's, garbage plugs
    Run Autolite 104's, with that setup.
    SSAC headers
    VS cam with L76 springs.
    180 thermo, no 160 ever.
    You dont need to under drive anything.
    Invest in a Wideband o2 sensor.
    And a ZZP canned tune is not what you want if you are going cammed, you will want a custom tune, hence why I said wideband.
  3. #3 Re: 1998 GP GT Top Swap Questions
    Mar 2012
    Rittman, ohio
    what size Pullley should i use.
  4. #4 Re: 1998 GP GT Top Swap Questions
    3.8 to start.
    Then go 3.6
    Because you are running a High compression block.
  5. #5 Re: 1998 GP GT Top Swap Questions
    Mar 2012
    Rittman, ohio
    does any have any thought of what to do bout any of my other questions
  6. #6 Re: 1998 GP GT Top Swap Questions
    Mar 2012
    Rittman, ohio
    bump or do i have to play the guessing game of trail and error
  7. #7 Re: 1998 GP GT Top Swap Questions
    Leave the stocker on.
    But run headers or plog/DP and go from there.
    With a car this old now, if installing a cam you're going to want/need the following:
    the cam
    New timing chain
    new timing chain dampner
    L76 valve springs
    LSx valve spring retainers
    Valve cover gaskets and grommets
    timing cover gasket
    aluminum LIM gasket
    And possibly new OE/LS7 lifters and possibly pushrods.
    Your transmission will quickly wear with the extra power and will need replacing or repair within a short few years if you use the power, which i expect is the purpose of being able to make it.
  8. #8 Re: 1998 GP GT Top Swap Questions
    Out West
    3.8 and headers.
    Whine with your Cheese?
  9. #9 Re: 1998 GP GT Top Swap Questions
    Mar 2012
    Rittman, ohio
    is there any merit to the MSD wires. i plan to run the stock pulley the cheap head gaskets for now actuall was thinking of runing the top swap kit front zzp and do the cam headers a little down the road after we get to run it for the time being.
  1. Just bought this 1998 gtp....and have a ton of questions..
    By MRJHERNANDEZ09 in forum Introductions/Noob Questions
    Last Post: 06-15-2011, 08:55 PM
  2. 1998 Tranny Swap to a 2006
    By MidnightBlue in forum General Tech Discussion
    Last Post: 05-13-2010, 02:25 PM
  3. 1998 Grand Prix GTP Transmission questions.
    By RavagerX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2010, 06:00 PM
  4. 1998 Grand Prix GT engine swap
    By aandbclark in forum General Tech Discussion
    Last Post: 12-03-2009, 08:04 PM
