Thread: Bogging
Results 1 to 20 of 20
  1. #1 Bogging
    GT Level Member boothe's Avatar
    Troy, Mo
    Car bogs around 55 60 at WOT but as i let the gas off a little it doesnt bog.. ign? Air flow? Trans?
    Sent from my Motorola Electrify using Tapatalk
    Troy, Mo
    Plugs and wires maybe 5k on them have MSD coils (yes junk but on car when bought 3 years ago) has own spectra filter. Could it be maf?
  3. #3 Re: Bogging
    Pennsylvania
    Scan it.
    Troy, Mo
    Dont have scanner
  5. #5 Re: Bogging
    It's not throwing any codes?
  6. #6 Re: Bogging
    flashing SES when WOT?
  7. #7 Re: Bogging
    Lets start at something simple...
    Not even a flashing SES light.
    Drive it to your local auto parts store and get the codes read, then get back to us.
    Troy, Mo
    No codes are being thrown
    Troy, Mo
    Bo ses on or flashing
  10. #10 Re: Bogging
    even if your ses isn't on you could still have a code stored in the pcm
    Troy, Mo
    Ill check it out after work then
  12. #12 Re: Bogging
    Pennsylvania
    1. MSD coils are probably shot. You WILL need to replace them sooner or later even if they aren't. Pick up some used stock coils. They're like $5/ea.
    2. It's not the MAF.
    Troy, Mo
    Was just told by a buddy that it was maf ge had dame problem
  14. #14 Re: Bogging
    If your gonna go to autozone or advance to get the codes read pick up a can of electrical parts cleaner and pull your maf sensor and clean it. It couldn't hurt even if it doesn't fix it.
  15. #15 Re: Bogging
    Pennsylvania
    You do know they sell actual maf cleaner, right? It's worth doing if you haven't, but the MAF's not broken; maybe dirty.
  16. #16 Re: Bogging
    Yeah but electrical parts cleaner works the same.
    Troy, Mo
    Ok will update shortly
    Troy, Mo
    Mafs clean idk what the deal is
    Ohio
    New coils yet?
    Troy, Mo
    Get them this week
  1. Bogging
    By goldgp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2011, 01:34 AM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
