Thread: Top Swap Won't Run Right
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: Top Swap Won't Run Right
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    yea its gtp pcm with a gt trans bin
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #42 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Have you tried installing the GT PCM and see if the same thing happens. Do you still have the L36 MAP sensor?
  3. #43 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    It starts but doesn't run well, yea i still have the l36 map
  4. #44 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    If it starts with the old PCM without uplugging the MAP then I would guess that your PCM is jacked up. You need a PCM from a reputable supplier.
  5. #45 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    I was looking overkill's pcm and thinking about getting one
  6. #46 Re: Top Swap Won't Run Right
    Grand Rapids, MI
    Quote Originally Posted by grandamle91 View Post
    http://www.grandprixforums.net/rpms-...ing-58482.html
  7. #47 Re: Top Swap Won't Run Right
    Minnesota
    Are you sure you have the MAP wired correctly? Sounds like a bad MAP to me not a bad PCM
    Do you have access to the file that is on the PCM or better yet...Who did you get the PCM from?
  8. #48 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    I'm pretty sure I did, i just matched wire colors up.
    I'm tring to find the post of the guy I bought the pcm from, but they all seemed to disappered. I know he lives up here by me in Sioux Falls, South Dakota. He drives a 99 ( i think) black 2 door gtp
  9. #49 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    It finally showed a code P0107, It still shows boost
  10. #50 Re: Top Swap Won't Run Right
    Minnesota
    Check the connector for voltage. If you are getting 5V at the connector IIRC than I would assume its the MAP sensor itself.
  11. #51 Re: Top Swap Won't Run Right
    It doesnt sound like its running properly.
  12. #52 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Heres a video i did last night
  13. #53 Re: Top Swap Won't Run Right
    Mar 2014
    michgain
    What was the problem I'm having the same issue
    . What was the issue because I'm having the same problem
  14. #54 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    still haven't figured it out, it won't start with the map plugged in. I've tried different maps, no luck. I can start it then plug in the map and runs fine
  15. #55 Re: Top Swap Won't Run Right
    Mar 2014
    michgain
    Yea I juss can't seem to figure it out
  16. #56 Re: Top Swap Won't Run Right
    Mar 2014
    michgain
    Quote Originally Posted by bklomp View Post
    So it wouldn't start with the map plugged in
  17. #57 Re: Top Swap Won't Run Right
    Mar 2014
    michgain
    Also did u do anything for a fuel pump
  18. #58 Re: Top Swap Won't Run Right
    Minnesota
    What MAP are you using and what file?
  19. #59 Re: Top Swap Won't Run Right
    Florida
    map is a 2 bar and pcm is 98... info on page 1
    my guess is the tune is not correct. you say the pcm is a 98 but you have a 99 tb/maf. the base files are diff there. who knows what else is incorrect in the file. if you have access to a DHP i can give you a hand setting up the file. my money is on the maf not set up correctly and the improper matching of maf tables...
    have you tried to wire back in a l36 map?
    what all have you tried in the past 2 years?
  20. #60 Re: Top Swap Won't Run Right
    Mar 2014
    michgain
    The tune is from zzp so that's good but I am also using a fuel rail from zzp come to find out that the fuel rail they gave me was using a gen 1 fuel regulator that wasn't keeping pressure and letting fuel in the vac line so they are making me a new fuel rail with the gen 2 regulator so we shall see how it goes
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. pcm swap
    By whiney6 in forum General Tech Discussion
    Last Post: 06-06-2010, 04:14 PM
  4. Cam for a top swap
    By matt5112 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 12:47 AM
