Thread: Top Swap Won't Run Right
Results 21 to 40 of 60
  1. #21 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Did you replace the PCM recently?...or during the swap?
  2. #22 Re: Top Swap Won't Run Right
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    during the swap
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  3. #23 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Do you have a stock PCM that you can try. The other guys earlier in the thread may be on to something.
    Do you know how to check the injector duty cycle with a DVM?
  4. #24 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    I'll throw my gt pcm and give it a try
    No i don't
  5. #25 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Well yea, check for vacuum leaks and swap the PCM. Be sure to update.
  6. #26 Re: Top Swap Won't Run Right
    Minnesota
    What MAP sensor are you using? I hope you switched over the the 2 bar L67 MAP otherwise the PCM thinks you have a 2 bar when you are running the stock GT 1 bar.
    I am almost 100% on that is what it is. I bet if you throw your GT PCM on the car it will idle better.
  7. #27 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    GTP map
    I'm kinda woundering if the pcm has a bad flash, now my ses, low oil light, brake light dont come on now
  8. #28 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    I was hoping the MAP was the answer as suggested by pure2sin. Damn!
    Before you put the old PCM back in make sure you check your grounds, battery and alternator. That's about all I can think of.
  9. #29 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Well after almost giving up for the day, (stock pcm did the same) I grabbed my gt idle air value and swapped them and guess whet she purred like a kitten
  10. #30 Re: Top Swap Won't Run Right
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Good to hear.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  11. #31 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Just weird it never set a code
  12. #32 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Oh man! Great!
    Since it didn't set a code I'm wondering if there is something wrong with the PCM. The return signal from the IAC to the PCM has to be within a strict set of parameters. If no code then .
    I'll have to remember this one!
  13. #33 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    I know. If I disconnected it and started it, it set right away. But I think i'm going to order a zzp pcm unless someone here has one better
  14. #34 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    You might want to go with overkill.
    I wonder if anyone else has an opinion on that.
  15. #35 Re: Top Swap Won't Run Right
    Texas
    When I did a SSIC I had similar symptoms as you are having. And it was Vaccum leak.
    85 Corvette
    01 TA
    03 Z06
  16. #36 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Quote Originally Posted by Rico View Post
    I woundering about theres but never could find any info
    Quote Originally Posted by txslow6 View Post
    Mine turned out to be the IAC runs great now
  17. #37 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Well now only problem I have now is the way I can get it to start is to unplug the map sensor then plug it in
  18. #38 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    Let me guess, no code...Right?
  19. #39 Re: Top Swap Won't Run Right
    Jun 2011
    Watertown, SD
    Nope. I let it run for about a hour and nothing. I can shut it down and restart it but if it sits for couple hours it just cranks
  20. #40 Re: Top Swap Won't Run Right
    Apr 2009
    Fort Worth TX
    So you're running the flashed PCM now?
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. pcm swap
    By whiney6 in forum General Tech Discussion
    Last Post: 06-06-2010, 04:14 PM
  4. Cam for a top swap
    By matt5112 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 12:47 AM
