Thread: TPS?
Results 1 to 4 of 4
Threaded View
  1. #1 TPS?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    The car is idling high, around 1500 rpm. I have no vac leaks, when I scan it, the tps sits at 2 or 5 %, if I disconnect the tps, the rpm normalizes.
    Next I do that procedure to adjust the tps: turn ign off, press gas to bottom, turn ign on, etc and it gets corrected to 0% and the idle rpm normalizes.
    The problem is that the issue comes back after a while or the next day until I adjust it again.
    I'm wondering it it's caused by the tps or something else.
    It's also not throwing any ses codes.
tps
