Thread: Swap 97 supercharged into 03 N/A?
Results 1 to 14 of 14
  1. #1 Swap 97 supercharged into 03 N/A?
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    Found a series 2 supercharged engine for sale out of a 97 grand prix. Im thinking of buying it redoing it and swapping it into my 2003 gt. Any major differences? It come with the tranny so i am hoping to drop the tranny and engine in as one. Will I have any troubles because of major changes from 97 to 03?
    2003 Grand Prix GT
  2. #2 Re: Swap 97 supercharged into 03 N/A?
    Leave your transmission.
    Take the top end.
    Enjoy the blower + higher compression...the way it should have been from the factory.
    To add, get some headers, a wideband, a tuner...keep the stock pulley and go to town, especially since your '03 transmission has the hardened 4th shaft from the factory.
  3. #3 Re: Swap 97 supercharged into 03 N/A?
    Feb 2009
    flintnasty MI
    I would highly suggest you swap the trans and everything directly with it, and run a 99 file.
    I just did this with my 99 and was glad I did not have to deal with building a hybrid na trans/ supercharged motor pcm file.... They are litterally impossible to do correctly, and the quirks of having the 3.29 gears in a gtp file are annoying to me.
  4. #4 Re: Swap 97 supercharged into 03 N/A?
    Jul 2011
    Ontario
    I heard that the tranny's in the gt's are weaker than the tranny's in the gtps? Is this true? Thats why i was thinking of taking the tranny from it too
    2003 Grand Prix GT
  5. #5 Re: Swap 97 supercharged into 03 N/A?
    Ohio
    03 trannys are different in alot of aspects from the 97-02 supercharged and 98-02 n/a
  6. #6 Re: Swap 97 supercharged into 03 N/A?
    Quote Originally Posted by Curt7 View Post
    '03 GT Trans > '97 GTP transmission.
    Only thing better is the HD diff, which can be shredded just as easy if you drive like a dummy.
  7. #7 Re: Swap 97 supercharged into 03 N/A?
    Jul 2011
    Ontario
    So am i able to run a 97 gtp engine with a 03 gt tranny and a 97 gtp pcm?
    2003 Grand Prix GT
  8. #8 Re: Swap 97 supercharged into 03 N/A?
    you have to get the pcm tuned for the different gears
  9. #9 Re: Swap 97 supercharged into 03 N/A?
    nope.
    03 trans needs 03 PCM.
    But it can operate any series II+ engines.
    But you'd need to change the file on the PCM for the engine you install.
  10. #10 Re: Swap 97 supercharged into 03 N/A?
    Jul 2011
    Ontario
    so keep my 03 pcm but program it for the engine and trans combo?
    2003 Grand Prix GT
  11. #11 Re: Swap 97 supercharged into 03 N/A?
    Feb 2009
    flintnasty MI
    I would highly suggest you swap the trans and everything directly with it, and run a stock 99 gtp file.
    already said this one.
  12. #12 Re: Swap 97 supercharged into 03 N/A?
    '03 Transmission WILL NOT work with a '99 file, Scott.
    Been there, done that.
    Just get a '03 GTP PCM, toss the '97 motor in, and put the gear settings to match the N/A transmission, done and done.
  13. #13 Re: Swap 97 supercharged into 03 N/A?
    Feb 2009
    flintnasty MI
    I clearly said that he should put the 97 trans in with it....
    I have tried to run a 03 3.29 trans boosted setup plenty of times with nothing but issues each go. Can it work, sure, but if you want simple, just toss the 97 trans in and leave your 03 around for a spare or sell it.
  14. #14 Re: Swap 97 supercharged into 03 N/A?
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    what about the engine harness is in it diffrent?
  1. 3.4 DOHC swap to a 3.8 supercharged
    By 1992gtp in forum General Tech Discussion
    Last Post: 02-21-2012, 07:58 PM
  2. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  3. My latest 3800 S2 supercharged swap
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 10-10-2011, 12:32 AM
  4. pontiac 3.1 swap to a 3.8 supercharged
    By kcrimson1991 in forum Introductions/Noob Questions
    Last Post: 02-16-2010, 10:34 PM
  5. Supercharged 3800 swap
    By biggz in forum General Tech Discussion
    Last Post: 09-06-2009, 03:07 PM
