Thread: Replacing radiator
Results 1 to 8 of 8
  1. #1 Replacing radiator
    GT Level Member boothe's Avatar
    Troy, Mo
    Need to know how to do this 1997 gtp
    Sent from my Motorola Electrify using Tapatalk
  2. #2 Re: Replacing radiator
    Pull dogbone mounts, pull fans, unhook trans lines, unhook low coolant sensor, unhook hoses, pull radiator out.
    Troy, Mo
    Bleed out through the bottom pull from the top?
  4. #4 Re: Replacing radiator
    St. Louis
    Yep. Just pull the lower hose off and drain it. I've never even messed w/ the drain on these things as they like to strip. Grip it and rip it!
  5. #5 Re: Replacing radiator
    Portland Oregon
    Nailed it. It also helps to remove the driver fender brace, part of the air box, and the battery hold down so the battery can shift back a hair for extra clearance.
  6. #6 Re: Replacing radiator
    I was going off the top of my head. I forgot there are 2 brackets that hold the radiator back held on with 10mm bolts. Just thought I'd throw that out there.
  7. #7 Re: Replacing radiator
    Details....................pfffft
    Troy, Mo
    Ha got it done guys 4 hours later and its good
  1. Radiator Cap??
    By RegorHtims in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 10:18 AM
  2. Radiator Cap
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 12:10 PM
  3. radiator
    By blown gt in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-14-2010, 09:17 PM
  4. replacing the OEM radiator
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2008, 06:09 PM
