LIM is lower intake manifold. If you're getting no heat inside (cold heater hoses) then you probably don't have it full of coolant and have an air pocket floating around. There should be a brass bleeder on the thermostat housing to help with this. I honestly like taking the thermostat housing off just so I can pour coolant into the LIM itself instead of trying to just fill from the radiator.
