Thread: Oh Noes! $2,000 Repair bill for my oil leak!
Results 1 to 20 of 26
  1. #1 Oh Noes! $2,000 Repair bill for my oil leak!
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    It looks like my oil leak is worse than I thought! This is what they said after they (GM dealership) looked at the car:
    1. Lower intake gasket is leaking
    2. Rear Valve cover gasket is leaking
    3. Rear main seal is leaking
    DAMN! I don't even know what that stuff is! They said around 2K to repair it. I dont have that kind of money!
    They adised me to do an oil change (which I need to do) and add some dye to it. Also before the oil change clean under the car and other areas.
    How bad does this sound? What can I do!?!?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    for that money you might as well buy a new engine.
  3. #3 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Feb 2008
    South Bend, IN
    go get a second opinion also.
  4. #4 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    TDCRacing
    Guest
    I thought you were gtting ripped off for a second....untill i saw the rear main seal.
  5. #5 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    TDCRacing
    Guest
    to be honest though. IF you lived closer i would do it for 1000 with parts and labor
  6. #6 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Bartlett, IL
    Quote Originally Posted by TDCRacing View Post
    Thanks for the info. About how long do you think the labor would take? 15 hours?
    How To: E-Brake Pwn
  7. #7 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    dude, thats a weekend job if you get a few friends and a few cases of beer. who said the rear main seal was leaking? how many miles are on your car?
  8. #8 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    GTP Level Member David99GTP's Avatar
    Florida
    I agree, round up some local GP owners/members and take a weekend to do it. Take the money you save and do some extra things to the car while you are at it. 2k will buy some nice mods
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  9. #9 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Bartlett, IL
    Mine is leaking Bio248!
    Weekend job! Thats actually good to hear. Do you have to remove the engine for this whole process?
    How To: E-Brake Pwn
  10. #10 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Apr 2008
    Chillin at the Beach , VA
    Basically yes. Have to seperate it from the tranny and there is a cover on the rear of the motor that has tocome off. That's where the seal is. With having to go that far, might as well get a good gasket kit and get them all done while it's out and don't have to worry about it once it goes back in.
  11. #11 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Bartlett, IL
    Doesnt sound like a weekend job to me... First I think im going to clean it at the local manual car wash. If im correct, its no a good idea to spray the top part of the engine bay with a power washer that has soap called "engine cleaner". I think I may be safe to clean the bottom of it though.
    After that do an oil change and pop some dye in there. If all goes well I should find out where it is.
    Quick question about the dye. Does it change the color of the WHOLE oil? So the oil will have a green tint to it? Or does the dye not combine with the oil and stay in tact?
    How To: E-Brake Pwn
  12. #12 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    TDCRacing
    Guest
    I'm not sure who told you to put dye in the oil but i have NEVER heard of that. Think about it, When dye is used it is to tell you where a leak is happening and is usually used on clear liquids or gasses.Perfect example would be freon in the a/c system. Or on something that when it leaks it is hard to see. Don't you think you can see where the oil is comming from when it leaks out?
  13. #13 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Barksdale AFB, LA
    It's not a good idea to pressure wash your engine bay at all. You could probably do the underside without too much risk, but the top end components don't take to high pressure water too well.
    2009 Subaru Impreza WRX STI
  14. #14 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Saraland Alabama
    the dye is uv and shows up under black light, and is the proper method for detecting a leak in any fluid
  15. #15 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Quote Originally Posted by Freebeer187 View Post
    The only dye i know of requires a special light and goggles to determine where your leak is coming from. Its not like your going to drop the dye in your engine and its going to turn it neon green to the naked eye. And if there is such a thing i have never heard of it.
    2006 Grand Prix GXP
  16. #16 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Feb 2008
    (Doesn't leak much oil)
    (Hmm of course it would have to be the rear one and not the front one that is covered under the recall)
    (could definatly leak a lot of oil)
    ("They adised me to do an oil change (which I need to do) and add some dye to it."
    So pretty much what I get from this sentence is...they don't know where it is leaking from.)
    I agree with getting another opinion. If you want to try to find where it is leaking from I would also advise against using the pressure washer under the hood; instead use either brake cleaner or carb cleaner and that will wash any oil away, making it easier to find new oil.
    Good Luck
  17. #17 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Bartlett, IL
    Quote Originally Posted by Blown97 View Post
    Good Luck
    HA Damn its nice having a badass forum to post problems like this.
    That makes sense. They dont know where its leaking from. F'in dealerships. Scum.
    How To: E-Brake Pwn
  18. #18 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Aug 2008
    White Rock, British Columbia
    Welcome to the world of the 3.8 litre engine. I love the engine but went through the same thing. Had to do all the seals which cost $1600. The last one was a GM recall so didn't hurt.
  19. #19 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    I live here. UR LOSN's Avatar
    Rockford, IL
    paying that much is crazy. thats when I wold take some vacation time and go to town on the car. never had the rear main leak......ever.
  20. #20 Re: Oh Noes! $2,000 Repair bill for my oil leak!
    Hoffman/Schaumburg, IL
    I dont think rear main leaks are that common on the 3.8....an if it isn't gushing, I could live with a rear main leak.....
    Also where the oil goes through the LIM, it shouldn't be able to leak out(well it can, but not a lot), coolant yes, but no pressurized oil flows through the LIM gasket, so it may just be the valvecover and it is running all the way down
  1. a good repair manual...
    By agent505 in forum Shops and Community Heroes
    Last Post: 08-07-2009, 07:45 AM
  2. seat repair
    By uti grand prix in forum Visual/Body Modifications
    Last Post: 08-14-2008, 11:35 AM
  3. Wheel repair?
    By TDCRacing in forum Tires & Wheels
    Last Post: 07-02-2008, 11:28 AM
  4. HeadLight Repair
    By Darkcelle in forum Off Topic Discussion
    Last Post: 05-23-2008, 09:49 AM
  5. Repair ABS Issues [*]
    By JJ91284 in forum How To Write-Ups/Tech Tips
    Last Post: 05-20-2008, 01:59 PM
