Thread: Fuel pouring out from under car when refueling.
Results 1 to 15 of 15
  1. #1 Fuel pouring out from under car when refueling.
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    My car is a 99 GTP and I recently purchased a fuel pump (ZZP350) and I've had it installed since I got it about a month ago. It works great but a few days ago I ran into a problem. I used the big o-ring that the pump came with that seals the canister assembly to the tank itself and now it is not sealing properly. I had no problems for the month or so since I installed it but now when I top off the tank fuel pours out of the gap between the canister assembly and the tank. I did not remove the canister or mess with anything at all, it just decided it didn't want to seal anymore. I checked and the snap ring that holds the canister assembly in place is installed correctly. I had a friend drive around while I was in the back seat looking through the trap door, and I could see fuel coming out when we went around corners and such. It is definitely coming out as a result of the canister assembly not sealing to the tank. Is there something I did wrong? Was the big o-ring that came with the kit supposed to be used there? Anyone seen this before? I've never heard of it happening so I'm at a loss and any help would be greatly appreciated.
    Ohio
    Did you replace the old oring for the one zzp sent you?
  3. #3 Re: Fuel pouring out from under car when refueling.
    Nov 2009
    Orlando
    Yes, I did.
    Ohio
    Did ya lube it?
  5. #5 Re: Fuel pouring out from under car when refueling.
    40-15'30'' N 085-40'33'' W
    My car did the same thing. I didnt put a fuel pump in like you did, but mine would leake like that. Yes the seal was supposed to go in there. I have seen the seal roll off the bottom of the canister and cause a leak. Its odd that yours didnt leak for a month then just started leaking. Sounds like you need to pull it out and see whats going on.
  6. #6 Re: Fuel pouring out from under car when refueling.
    Nov 2009
    Orlando
    I did not lube the o-ring before installing. Never even thought about it. What kind of lube is used in fuel tank areas? I pulled the canister and checked it out and I couldn't tell that there was anything obviously wrong. And yeah I thought it was weird that it was fine for like a month and then just stopped sealing. How does that even happen?
    Ohio
    I use plumbers grease so it sits properly. Squeeze it so it folds and see if it cracks anywhere.
  8. #8 Re: Fuel pouring out from under car when refueling.
    Nov 2009
    Orlando
    The 1 snap ring is the only thing the holds the canister down in the tank right? Theres not like some secondary mechanism thats supposed to hold it in place is there?
    Ohio
    Nope, just the b1tch on the top.
  10. #10 Re: Fuel pouring out from under car when refueling.
    Saratoga NY
    Just the snap ring, on the pump the rubber o ring has to be in the right groove (upper last or top IIRC) of the canister to seal properly, to lube it use Vaseline.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  11. #11 Re: Fuel pouring out from under car when refueling.
    Sep 2011
    Copperas Cove, TEXAS
    This happened to me also, the old o-ring had been pinched and leaked. I got a new o-ring and lubed it with dielectric grease, it held in place. It was a PITA to get that snap ring on though.
  12. #12 Re: Fuel pouring out from under car when refueling.
    Nov 2009
    Orlando
    I use a pair of needlenose pliers and the ring doesn't give me a huge amount of trouble. For a sec I was like "Oh god its too easy it must be broken" lol
  13. #13 Re: Fuel pouring out from under car when refueling.
    Nov 2009
    Orlando
    So I opened it up again and checked out the gasket. Visually it looked good to me but who knows. I lubed it up with some vaseline and reinstalled everything, problem persists. Nobody has had an issue where it was something other than the o-ring have they? I don't even know what but something different in that same area. Almost afraid to ask lol.
  14. #14 Re: Fuel pouring out from under car when refueling.
    FWIW I always lube with vasoline and never have a sealing issue.
    Why vasoline you ask? Because it melts/breaks down in almost anything w/o any issues.
    Ohio
    I think it's gotta be the assembly is cracked or something.. I'd pull it out and inspect the hell out of it
  1. Refueling
    By devante46 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2012, 11:32 AM
  2. Replacing CV shaft and trans fluid pouring out
    By ggsz28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-03-2011, 12:51 PM
  3. Pouring Coolant?
    By tmackster in forum General Tech Discussion
    Last Post: 02-05-2011, 02:41 PM
  4. Coolant pouring out of TB upon throttle!!!
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2009, 12:17 AM
