I have a 1999 Grand Prix GTP, it drove just fine an hour ago and then when I went out to go to the store it would not fire. It turns over just fine but cant even get a sputter out of it. When I sit in the car and engage the key to the "on" posistion I cant hear the pump engage, but then again, this is only a trick I have learned on other cars that I have had. It has 112,000 miles on it and the pump has never been replaced.
Is this a pretty clear sign that the pump is bad or shold I check some other things. I am also going to throw myself under the bus here and admitt that I am one of those people that runs his tank almost empty before filling up, now I learn that can heat up a pump pretty good and shorten the life. Lesson learned.
Thank you in advance for your help
