first off if this is in the wrong section please move, not sure where this would fall. But now to the problem, ill explain as best i can, when im under light/moderate acceleration i can feel a shudder throughout the car (mainly right after the 2-3 shift when the rpms are really low) but its throughout the whole powerband. I did notice that the dogbone mounts and motor mount over the radiator do have a lot of play and they look cracked. I was wondering if the shuddering could be a result of those mounts being/going bad? also when the car is first stvrted it will go into lockup fine while crusing, but after the car gets to operating temp and im cruising it will pop out of lockup. it shifts through all four gears fine, but just no lockup unless i restart the car. ive heard that they will pop out if knock is detected? can anyone put any truth to that? and my thinking is the shuddering might be registering as false knock. the shudder/vibration gets worse when the wheel is turned to the right if that helps also. thanks for reading my novel guys and any input is appreciated.
