Thread: Removing the Boost Bypass Valve?
Results 1 to 8 of 8
  1. #1 Removing the Boost Bypass Valve?
    GT Level Member lilrocket's Avatar
    landis,nc
    Ok ive been looking and i cant really find any Intel on this. Why would you remove the bbv off the supercharger, is there any performance gain in doin this or loss, i have seen it on a few cars specially just going through glancing at picture and noticed they were gone plus one of the gentelman thats showed his car with us last year had his removed. Looking at his the only thing i noticed was how it sounded when he fired it up sounded like it had a mild cam in it but it wasn't, does any one know anything about doing this?
    98 DAYTONA 1110/1500: work in progress
    00 DAYTONA 216/2000: totaled but not forgotten parts car
    "Speed its my drug, the faster i go, the faster i want to go!"
    Its in the case.
    Its not worth the loss on fuel economy.
  3. #3 Re: Removing the Boost Bypass Valve?
    landis,nc
    so the only loss is in fuel economy none in performance?
  4. #4 Re: Removing the Boost Bypass Valve?
    you want that valve so the car is able to dump boost in the right situations. without it you could end up in a bad place.
  5. #5 Re: Removing the Boost Bypass Valve?
    I can't. My PCM is setup to maintain the same AFR in TCS and any other scenario where you'd typically see the BBV solenoid force the BBV open.
    Quote Originally Posted by lilrocket View Post
    Correct. But likewise, there is no gain in performance either.
  6. #6 Re: Removing the Boost Bypass Valve?
    i agree in your situation, i had mine run the same way, remember?
    he has a GTP, so his is all setup to function correctly. therefore he should leave it as is.
  7. #7 Re: Removing the Boost Bypass Valve?
    Agreed.
  8. #8 Re: Removing the Boost Bypass Valve?
    It's put there from the factory for a reason.
    One of the things on a L67 that shouldn't be messed with.
  1. boost bypass valve instructions
    By mosinnagant in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2011, 12:21 PM
  2. Boost Bypass Valve is it the same as a BOV?
    By xsvtank in forum General Tech Discussion
    Last Post: 08-06-2010, 12:12 PM
  3. how do i check my boost bypass valve?
    By bluevet03 in forum General Tech Discussion
    Last Post: 04-26-2010, 01:30 PM
  4. Boost Bypass Valve help
    By mikeh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2009, 01:20 AM
  5. Boost BYpass Valve capped Off?????
    By Uno99 in forum General Tech Discussion
    Last Post: 10-19-2009, 07:48 PM
