Thread: Help! Weird KR Issue
Results 1 to 14 of 14
  1. #1 Help! Weird KR Issue
    Oct 2011
    Puyallup WA
    Ok guys I have this really odd kr issue...at wot i will see 3-4 degrees of kr...I get some kr going up a hill and the Torque convert locks...most the time I have 0 kr driving to and from work which is about 30 min...then if I have to stop at the store and the car sits for over 20 mins then when I start it up and start driving it will spike up to 10 degrees of kr for about 5 seconds then goes away...seams to be worse if it sits for around an hour...this kr is under very light throttle and its always when I am pulling out of the parking lot or pulling onto a side street...so its always prob under 30 mph...there is no kr at idle and none when in gear idling...only when starting to accelerate under light throttle...car only has dp and intake stock tune stock pulley...if anyone has any ideas I would love to hear them thanx Toby
    08 G8 GT - exhaust Tune
  2. #2 Re: Help! Weird KR Issue
    Oct 2011
    Puyallup WA
    No one has heard of this?
  3. #3 Re: Help! Weird KR Issue
    Mileage on the car?
    Condition of the motor/trans mounts?
    Larger diameter downpipe could be making contact with the sway bar under load, causing false knock.
    Is the downpipe catted? If not...do you have an o2 simulator in there?
  4. #4 Re: Help! Weird KR Issue
    Pennsylvania
    That shouldn't matter... unless it's a used cat with like 150,000 miles on it...
  5. #5 Re: Help! Weird KR Issue
    Quote Originally Posted by SlowNA06 View Post
    It should because using an o2 simulator in any '01+ car screws with cat diagnostics and fuel trims.
    I'm not talking about the converter failing here.
    Also, try to add a little pipe inbetween the filter and the MAF, sometimes the filter bolted on the end of the MAF can skew MAF readings causing crap readouts and messing with the tune. Been there, done that.
  6. #6 Re: Help! Weird KR Issue
    Pennsylvania
    Oh oh oh oh oh right you are. My bad.
  7. #7 Re: Help! Weird KR Issue
    Oct 2011
    Puyallup WA
    94k
    motor mounts look good
    92 oct every tank
    new plugs
    new wires
    cleaned maf
    downpipe is not even close to swaybar
    running rear o2 without sim(going to turn off CEL with HP Tuner)
    All I can think of right now
  8. #8 Re: Help! Weird KR Issue
    Oct 2011
    Puyallup WA
    DP is catless
  9. #9 Re: Help! Weird KR Issue
    Oct 2011
    Puyallup WA
    Ok ill try that for sure...I have the filter attached directly to the maf
  10. #10 Re: Help! Weird KR Issue
    Pennsylvania
    How many miles?
    Use 91+ octane
    Replace fuel filter
    Clean MAF sensor
    Clean throttlebody
    Fresh spark plugs
    Fresh spark plug wires
    Check for vacuum leaks
    Inspect lower engine mount
    Flush coolant
    Check/change oil and filter
    Clean air intake filter
    Scan
  11. #11 Re: Help! Weird KR Issue
    Jersey
    flip your dog bones and do everything else that was just said
    16' wrx sti- stock
  12. #12 Re: Help! Weird KR Issue
    Topeka, KS
    I have the same problem dude. I used to be kr free. It just happened out of the blue that my car wants to be a knock monster.
    So when you give it light throttle above 30% it spikes kr like crazy then goes down right ?
  1. Weird Issue
    By Slick2500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2012, 01:51 PM
  2. weird cooling issue
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 05:44 PM
  3. weird car issue
    By NashGT02 in forum General Tech Discussion
    Last Post: 07-29-2010, 09:16 AM
  4. Weird Sub Issue
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2010, 10:11 AM
  5. Weird ABS issue
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2009, 12:06 AM
