Thread: Starting Issues Need Help
Results 1 to 9 of 9
  1. #1 Starting Issues Need Help
    Jacksonville, Fl
    I have been dealing with start up issues lately. First my starter went bad, i replaced it and everything was gravy. Now about every other cold start, it turns over fine but it does not catch. it seems like a fuel problem. In order to get it to catch, I have to give it gas as im turning the key. As soon as it fires up, it is fine. i replaced one of the relays and i just discovered there is a second one. does this sound like a problem with the relay, fuel pump or what?
  2. #2 Re: Starting Issues Need Help
    Jun 2011
    To start your car, you first need to locate your keys. After doing so, insert them into the ignition. If applicable, depress the clutch and turn the key to the on position. You should get a 'wah-wah-vrooom' sound from under the hood.
    That is called an engine. It provides the car with the power to move forward. Sometimes engines have lots of power and they make the car go, what is technically called, fast. An engine runs via pixie dust, clown farts and sunshine. You can pick these items up at any local fueling station. Depending on your locale, it should run you around 20 rabbit pelts to fill up.
    Once your car is started, you will want to put it into gear. Don't do that! Just sit there and look pretty sitting in your car. The girls will flock to you and the guys will envy you.
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Have u changed the fuel filter ever?
  4. #4 Re: Starting Issues Need Help
    Jun 2011
    Whats a filter?
  5. #5 Re: Starting Issues Need Help
    Jacksonville, Fl
    no i have not. i bought it with a blown motor and rebuilt it little less than 10k miles ago. so i inherited all the problems too haha. ill try replacing the filter and see what happens
    Dec 2011
    Grand rapids Mi
    Quote Originally Posted by WOTFTW View Post
    It's probably one of the cheapest places to start.
  7. #7 Re: Starting Issues Need Help
    did you clean the throttle body when you did the engine swap? or rebuild as it may be.
    what year is your car?
  8. #8 Re: Starting Issues Need Help
    Jacksonville, Fl
    I have a 97 gtp. I rebuilt and cleaned everything.
  9. #9 Re: Starting Issues Need Help
    Jacksonville, Fl
    theres only a few things i didnt really touch. which are... rack and pinion, fuel system and the electricals.
  1. starting issues
    By ctracer in forum General Tech Discussion
    Last Post: 08-29-2011, 05:26 PM
  2. Starting issues!! Help please!!
    By 98 Grand Prix Gt in forum General Tech Discussion
    Last Post: 07-29-2011, 03:19 PM
  3. Odd starting issues.
    By squeaks130 in forum General Tech Discussion
    Last Post: 01-18-2011, 12:54 PM
  4. Car Starting Issues!
    By Cal Cross in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2010, 12:44 PM
  5. Starting Issues
    By BigBird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2009, 12:22 PM
