Thread: Thinking of putting a 3.8 SC in my 99 s10
Results 1 to 20 of 27
  1. #1 Thinking of putting a 3.8 SC in my 99 s10
    SE Level Member rc10gt7090's Avatar
    Jun 2011
    minneapolis
    So last fall I had a guy come over in an 80s shelby charger that had a 3.8 SC motor in it and I had told him about my plans to put a v6 in my s10 we both knew it could be done but he suggested that I put a 3.8 in my s10. Instead of the motor from an s10 blazer. Do to I would get more power out of the 3.8SC
    So is this a worthy project or should I stick with my original plans?????
  2. #2 Re: Thinking of putting a 3.8 SC in my 99 s10
  3. #3 Re: Thinking of putting a 3.8 SC in my 99 s10
    I want a S10
  4. #4 Re: Thinking of putting a 3.8 SC in my 99 s10
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    As a Moderator over at S10Planet.com, I DEMAND you sign up and create a project thread if you decide to take on this task, lol. I know you would have quite a few followers over there if you join up.
    It might even be worth it to join up, do some research, and talk to "Neo" He is our resident swap guru when it comes to S-series trucks and 60 degree and 90 degree engines.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  5. #5 Re: Thinking of putting a 3.8 SC in my 99 s10
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    You're talking about the Vortec 4300 vs an L67? Uhm, L67. More power, more fuel efficient. I wouldn't tow with it, but if its just a drive around truck (which an S-10 is), an L-67 would be cool.
    The evil LG8 still refuses to die.
  6. #6 Re: Thinking of putting a 3.8 SC in my 99 s10
    Jun 2011
    Detroit, MI
    Pretty sure someone on here had one. A red one.
    iLoveSpade
  7. #7 Re: Thinking of putting a 3.8 SC in my 99 s10
    The problem isn't getting the motor in it's getting a trans that will bolt up and take the abuse.
  8. #8 Re: Thinking of putting a 3.8 SC in my 99 s10
    Jun 2011
    Detroit, MI
    Nevermind this is the one I was thinking of, its a Colorado... and doesnt have a 3800 http://www.grandprixforums.net/my-04...ead-35249.html
    iLoveSpade
  9. #9 Re: Thinking of putting a 3.8 SC in my 99 s10
    Charles City, IA
    Just take a 5 speed out of a camaro.
    SMGPFC Two Nipple General
  10. #10 Re: Thinking of putting a 3.8 SC in my 99 s10
    Jun 2011
    minneapolis
    So I’ve taken out the whippy 4 banger motor and I do have a 4.3or v8 to put in. but that seemed too common of a project. The only problem I see is making motor mounts and routing the intake for the SC and the wiring for the new computer
  11. #11 Re: Thinking of putting a 3.8 SC in my 99 s10
    Mercer, Pa
    Superchargered 3.8 into any rear wheel drive is tuff. There would be dozens of Camaro's that way if the inlet end of supercharger wasn't touching fire wall. Then you have to mount a throttle body and stuff. You need a auzzie m90 for rear wheel drive but not many in the states.
  12. #12 Re: Thinking of putting a 3.8 SC in my 99 s10
    Kemmerer, Wyoming
    one of the problems would be matching it up to the tranny. if it came with the 4 cylinder you might be ok but if it came with the 4.3 the bellhousing wont match up. also you would have to worry about the placement of the alternator.
    Bunnell, FL
    Check out fullthrottlev6 they swap the m90's into rwd all day.
    Android Fire
    I'm a Sex Offender
  14. #14 Re: Thinking of putting a 3.8 SC in my 99 s10
    utah
    the 2.2 trans will bolt directly....it will also explode directly after you drive it ten feet
    Mercer, Pa
    I agree it can be done but the first thread I looked at says the same thing I just said.
    "can it be done yes
    can it be done easy... no
    i didnt modify the supercharger but i did modify the firewall so its one or the other"
    http://www.fullthrottlev6.com/forums...0-my-m90-build
    Mercer, Pa
    From the last page of that thread.
    "long story short i dont recommend this swap unless you really want to and have enough of your own knowledge to do it because youll get your self in way to deep and no one will be able to get you out"
    Quincy, Mass
    Why not use a v6 camaro engine and trans and then do a top swap?
    No more GP 04 Impala SS Indy:
  18. #18 Re: Thinking of putting a 3.8 SC in my 99 s10
    You could, but you'd need to mod the case to clear the firewall.
  19. #19 Re: Thinking of putting a 3.8 SC in my 99 s10
    utah
    Or run the holden parts...both spendy
  20. #20 Re: Thinking of putting a 3.8 SC in my 99 s10
    Quincy, Mass
    or mod the firewall to clear the case
  1. Whats Best For Putting Badges On?
    By burgundybullet in forum Visual/Body Modifications
    Last Post: 11-03-2011, 09:25 PM
  2. What are they putting in food these days?!
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 03-09-2011, 05:25 AM
  3. Can't get key out after putting car in park.
    By Dusty02se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2010, 02:44 PM
  4. Putting Motor In
    By dcbur2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2009, 10:44 AM
  5. Anyone ever try putting a 5 speed or something in a 97+ GP?
    By salannelson in forum General Tech Discussion
    Last Post: 11-15-2009, 01:11 AM
