Thread: 8 rib
Results 1 to 20 of 23
  1. #1 8 rib
    Bunnell, FL
    Tried to search but the forum says its too common.
    So pros and cons to doing the upgrade?
    Android Fire
    I'm a Sex Offender
    Pros: sweet wide belt and less belt slip. You also need another balancer and have an opportunity to get a overdrive balancer.
    Cons: its not cheap.
  3. #3 Re: 8 rib
    but until you have belt slip, its probably not worth the cost.
    Isn't a belt slip less money than a 8 rib setup?
    $150 from WBS for belt wrap, memeber here charges 170: http://www.grandprixforums.net/gen-v...able-7358.html
    190 for the kit from ZZP for an 8 rib, balancer, and pulleys.
    All prices + shipping.
  4. #4 Re: 8 rib
    GTX Level Member crbquist's Avatar
    Massachusetts
    Only worth it if you are planning to run a tiny pulley
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
    Mercer, Pa
    At what psi or pulley size does slip become a problem?
    Bunnell, FL
    Well I was wondering as I'm getting everything to do it. Along with a new snout (to me) with mps. And two pullies, and the belt for fairly cheap.
    Anyone know where I cam get an 8 rib for a 3.8? Zzp is a lot vauge
    Android Fire
    I'm a Sex Offender
  8. #8 Re: 8 rib
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    More power losses using an 8 ribber if you don't need it.
    Bunnell, FL
    That's fine. I'm not too worked about the extra paracitic loss
    Android Fire
    I'm a Sex Offender
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    How much extra parasitic lose compared to a 6 rib?
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
    Mercer, Pa
    It's a fair amount of work to change the balancer, the bolt is extremely tight (200 to 300 foot pounds) and you have to keep motor from spinning while breaking loose the bolt. Most impacts won't break them loose. You will need a case learn when done and you also need a puller to remove balancer. Again that bolt is really tight!
  12. #12 Re: 8 rib
    Quote Originally Posted by sseilmnop View Post
    Belt slip isn't a big problem on Bonnie's (smile).
    As far as tough to change an HB, it's not hard at all. My impact rips the bolts off w/o a problem. I've only had one fight and it was on a stand for a cam swap.
  13. #13 Re: 8 rib
    Bunnell, FL
    my friends helping me do mine. and he' dont the install twice so far
    I'm a Sex Offender
  14. #14 Re: 8 rib
    Pennsylvania
    Smoothflow Pulleys
    Good guy, good work.
  15. #15 Re: 8 rib
    Quincy, Mass
    zzp and intense mps pulleys come as 8 ribs dont they?
    No more GP 04 Impala SS Indy:
    Bunnell, FL
    Zzp's do that I know. Not sure about intense tho
    Android Fire
    I'm a Sex Offender
  17. #17 Re: 8 rib
    Charles City, IA
    Intense does also, they are pretty well identical.
    SMGPFC Two Nipple General
  18. #18 Re: 8 rib
    Bunnell, FL
    anyone have some pics? about time this thread got some porn
    I'm a Sex Offender
  19. #19 Re: 8 rib
    Pennsylvania
    Smoothflow
    ZZP
    Orange County, NY
    I actually purchased the smooth flow 8 rib kit......it was NOT an 8 rib kit. Not wide enough.
    The owner nate is a nice guy though. Offered to machine me a set to my specifications.
rib
