Thread: Timing and knock results
Results 1 to 4 of 4
  1. #1 Timing and knock results
    SE Level Member Rudd97gtp's Avatar
    Greensburg, IN
    Ok so I had the aero on knock and advance timing and from idle to wot the knock showed nothing the timing at idle is 21 or so and then with giving throttle it goes down 19 and then at wot it goes as high as 25 and then after releasing the throttle it bounces to 30.
  2. #2 Re: Timing and knock results
    Portland Oregon
    That's A LOT of wot timing. If that's accurate then I am amazed you're not getting KR
  3. #3 Re: Timing and knock results
    Jebus, how has it not blown up yet.
    Greensburg, IN
    Idk?!??!? What is normal? So is the tune responsible for these numbers so I am gonna find a 3.4 pulley and a tune? How much does a tune usually run
  1. GTP Dyno Results!!!
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-17-2011, 11:25 PM
  2. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  3. Results with stalls?
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2010, 02:49 PM
  4. results on the 07 ss
    By joe deleon in forum Track Sessions and Kills
    Last Post: 05-10-2009, 01:06 PM
